Problem with electrics
Old Sep 23, 2012 | 07:29 PM
oilbim's Avatar
s55
I deliver the car. The switching shifter of AKPP is not switched, is blocked. I turn on the light, starts to blink "!" ESP on the dashboard. ABC does not rise and is not omitted from the button. I wait for 10 minutes. I press a brake - the switch of a box works. In 15 minutes ESP works and from the button ABC rises and omitted. what's the problem?
w220 S55k 2003
Old Sep 23, 2012 | 08:11 PM
cmpcpro's Avatar
2004 CLK 500
Did you replace or reset the battery? Perhaps it had to re-calibrate itself? If you unplug power from a W220 it has a whole mess of systems that are like crying babies when you plug it back in.. they all want attention or they act up.. the lights on the dash will go away after a while on their own.. I usually drive around, turn the wheel from lock to lock and after a bit they're all gone.. if that's what you are facing.. I had a little trouble understanding..
Old Sep 23, 2012 | 08:37 PM
oilbim's Avatar
s55
No, it is not connected with the battery. I think it the SAM block any have broken
