shake at idle
About the size of a large softball. My mechanic charged me 0.5 hour (minimum) to replace it, but it really only took him 15 minutes once he lifted the car up.
If you haven't replaced the plugs I'd look there first. FYI, 2 per cylinder.
Also check that the ignition wire boot is snug on the wire. My wife's E500 had a slightly rough idle, also no codes, and it turned out that two of the plug wires (different cylinders) were loose. Cleaned them off, plugged them back on tightly, and no more vibration.
The tranny mount is $25 and 15 minutes labor
there are 16 plugs so about $100 and several hours labor. Plus numerous people have screwed up their car when trying to DIY the plugs and wires as preventive maintenance, when there wasnt any problem
