Transmission service on a low miles car
I realized transmission fluid is more susceptible to heat than time but 13 years is a long time too. Searched the site and most transmission service questions are related to higher mileage car than this ultra low miles car. Thank you for your advuce.
They have just released a new formula ATF.
NAG2 (mb 7 speed) transmissions have an ungraded fluid that is backwards compatible with NAG1 but I am not positive where Shell ATF134 stands on being in spec for NAG2's.
If you use a "fluid exchanger " without dropping and cleaning the pan, it circulates the metal shavings thru the tranny and damage results . What good is changing all the fluid if you are stirring up the gunk on the bottom of the pan?
You can use a fluid exchanger to do a full fluid change. but you should only do it after you drop and clean the pan
Questions:
1). Why change the transmission fluid every 4 years and not 5 or 6 years? Not being disrespect on your advice :-). Just curious on the number and being due diligence, and hope to learn something along the way.
2). Servicing the torque converter: is it just replace the fluid or the parts? Want to make sure what it is involve so I can talk “intelligently” with the mechanic.
Transmissions with over 100,000 miles have been known to fail after a change like those in BMW's but I know of none with the MB transmissions. Apparently dirt that has settled in the nooks and crannies gets dislodged with fresh fluid and then gets stuck in the pathways within the transmission.
Most owners don't even bother to change the fluid since they plan on selling the car before troubles start by not changing it.
The only real way to change the fluid so that ALL of it is replaced (flushed) including the fluid in the transmission, torque converter, cooler and pipes is to perform a flush as explained in this thread
http://www.benzworld.org/forums/w211...722-6-a-2.html There are other threads as well like this one that are just as good if not better.
There is no serviceable parts in the torque convertor.
Almost all techs/mechanics will not do a full flush described above unless you force them. Most drop the pan, change the filter, and refill. This is approx. half of the fluid. Some people use this method and then drain and refill several times after until the dilution of old fluid is very small compared to the new fluid.
While you are in there, change the electrical connector P/N 2035400253. Its cheap, easy and worth it. Buy original Mercedes for this part since after market can have incorrect O-ring specs.
The satisfaction in correct operation is very dependent on having the correct level when done. Better to under fill and top-up slowly and never overfill. There is a dipstick for this p/n 140589152100 that your mech/tech must have.
hope this helps!
The "sealed for life" is ridiculous & no longer recommended by MB. Oil needs to be changed regularly, PERIOD.
