Need help with crankshaft position sensor
So, now, we have a new CPS and the car runs, but will get hot, and the burning smell, which we think may be the alternator. I have ordered one which will be in on Monday.
Today, while messing around under the hood, my husband moved the wiring connector to the CPS and the car died. i restarted it and when he moved the wiring and connector again it died again.
Is it possible for the wiring/connector to be bad? and if so, how do you go about replacing it. I looked online and couldn't find one, then, called the dealer and they don't sell that as a part.
Regarding the engine cutting out after the CPS was changed, it does sound like the connector is not fitted correctly, or there is problem with the pins or wiring near the connector. If you have a smell like that then you should be able to see some evidence at the connector and CPS connector wiring by now. If not then you have something else wrong as well. You need to find the source of the smell I guess.
