im seeking mercedes benz s class (w220) Bose audio wiring schematic and D2B answers
Old Aug 22, 2014 | 10:55 AM
billr979's Avatar
2000 mercedes benz s500
The previous owner has cut out the cd changer and installed Fosgate amp to replace the Bose amp:-(....Can anyone point me in the right direction on getting it as close to "factory" as i can. Thank you in advance.
Old Aug 22, 2014 | 04:19 PM
PhazonPhobe's Avatar
2003 S600 Designo Graphite
See...I'd actually like to do the opposite and upgrade my Bose system to a more modern, more powerful system. But I've heard it's a bear to get into those Bose systems.
Old Aug 22, 2014 | 06:43 PM
seven_out's Avatar
SL500, Miata
I too would be looking to upgrade back to the original factory system. You should be able to find the audio components you need priced reasonably on eBay.
The schematic for the original audio system is attached along with a legend.
Attached Thumbnails im seeking mercedes benz s class (w220) Bose audio wiring schematic and D2B answers-s500-audio-schematic.jpg
File Type: pdf
Old Sep 1, 2014 | 10:59 PM
billr979's Avatar
Can u tell me which colors are to the Subwoofer i appreciate this greatly.Thx in advance
Old Oct 29, 2014 | 10:25 PM
madmouse28's Avatar
2003 Mercedes-Benz S500
The sound system is fiber optic and will be a very big task to put back to original. I would consider leaving it as is unless it is no working correctly , someone paid a lot to up grade the system.
Old Oct 30, 2014 | 08:55 AM
FlyingScot41's Avatar
S320
Wiring and Fiberoptics
The wiring and fiberoptics are not that difficult to replace but it is a lot of work. I have the same problem on my W220. Some idiot cut the wiring harness and the fiberoptic cables in the boot. I have checked with my Mercedes main dealer and the full harness from the Bose Amp to the Command is available and cost around £350 or about $560. Most of the harness is under the floor so the seats have to come out. I managed to find a complete fiberoptic harness on eBay for about £100 ($160 ish). Once you have the harness it is a matter of being methodical. Free off the harness but don't disconnect anything lay the new harness alongside the old and make the connections as you disconnect. Do the same for the fiberoptic system. Remember that the Command system will need to have a STAR visit to get the Bose amp recognised by the system. Mercedes main dealer recommended that I find the harness identification number for the harness fitted to my car and they would order in the harness from that number, same for the fiberoptic harness. The fiberoptic harness from Mercedes is about £121 ($195 ish) so buying new is not much different to buying from eBay! The Bose system is by far the best system for the car because it was designed and tuned to the cabin acoustics for the W220. Yes it may not be as powerful as a more modern system but the sound quality is superb.
Old Oct 30, 2014 | 11:10 AM
madmouse28's Avatar
I attached a schematic hope this helps and good luck.
Old Jan 30, 2017 | 06:02 PM
hegar817's Avatar
2003 s55
Anyone know where I can get a schematic for a 2003 model?
Old Jan 30, 2017 | 09:26 PM
vmystikilv's Avatar
Range Rover
If the fiber optic line itself has been cut, chalk the system up as a lost....
Old Jan 30, 2017 | 09:51 PM
hegar817's Avatar
2003 s55
Reason I ask is because my fan radio stays on at all times even with the key removed. Radio also can be powered on if the power button is pressed. I think the radio fan may be the culprit to why my battery dies every day. Can any of yalls radios be powered ON with the key off? Wonder if it is the radio itself or a wiring issue.
Old Jan 31, 2017 | 04:09 AM
renault12ts's Avatar
W215 CL500 2005
Yes, it is a feature, all COMAND systems can be powered on with the key out.
Old Jan 13, 2024 | 01:39 AM
Mr. S500's Avatar
02's500 w220
Mine also does that power w key off i thaught it was normal
my fan doesnt stay on it might be the fan on your ac control module
Old Jan 15, 2024 | 09:39 PM
Fried Chicken's Avatar
2005 S500 Designo
I get now sound from the speakers when the car is cold... I don't have an explanation for this, on the head unit everything appears to work as it should, although sometimes the mute icon won't appear when pressed. I'm thinking bad caps, but maybe it's as simple as a bad fiber optic connection to the amplifier?
Old Jan 16, 2024 | 03:55 PM
tusabes's Avatar
Mercedes
amp in trunk often gets water damage get a used in eBay
Old Jan 18, 2024 | 06:22 PM
2005 S500 Designo
Already done this like twice. Have one sitting here, considering replacing the caps
