Haven't changed oil in about a year
Our 01 S500 has only had it's oil changed once in the two years of ownership. Right now, it's got about 23,000 miles on it and FSS reports about another 700 before B service.
I checked the oil to make sure it's not black or anything and it's still pretty good, even for the length of time it hasn't been changed.
This won't cause damage to the engine right?... not having changed the oil for a while (I think about a year now) because this car is really just driven on weekends or short trips once in a while.
-G-
I just go with the FSS, plus dad doesn't want me changing it anymore then what Mercedes reccomends. Personally at first I felt very very touchy of having it go even more than 6K miles without a change, but we're at 15k now with only one change and so far so good.
Synthetic oil is a must for newer MBs.
With 700 mi, you should just change it. The FSS tracks mileage as well as time. After about a year, it will tell you to replace the oil by giving you the number of days left instead of miles. If your car isn't driven often, water gets condensated in the engine block and that dilutes the oil and causes rust. Normally, condensation is burnt off by frequent engine starts.
Hey all,
-G-
it's easy and clean.... MB dealers do the same thing...
they suck out the oil through the dip stick port....
m1 from costco.... don't need that european weight either... non-sense...at least for me since i'm in so. calif...
JR
