ABC struts and valve blocks asking price?
With that said, how much could I get for 4 good stuts and valve blocks and everything else associated with it? Everything else is good except for the high pressure line, obviously.
Thanks in advance.
An abc pump , strut or valve block failure is when to switch to strutmasters, not a hose failure
Any local hydraulic shop can repair it for you quickly, cheaply and easily. They can replace the flexible hose with a new section that is welded, compression fitted or flared onto the existing pipes.
Nick
