W220 A Few Problems
1: When I hit the rear window automatic up button the back windows come up halfway then go back down without hitting any buttons. If I manually hold the button up they come up fine and shut.
2: My driver headlight is purple and flickering (I have a bi-xenon headlight) and I think a new bulb will fix it. Or is there something else that is making it flicker?
3: I am having an issue with my key fob where it will not unlock/lock the car. I have changed the battery 3 times and it is still not working. It is like the key fob I am holding is for another car. However the car can be started with the smart key it just wont lock, unlock or open the trunk.
4: When the key fob DID work and I try to open the trunk with it, the trunk opens a few inches then stops. I click the button on the key fob again and it goes up another few inches and stops again. However when I click the automatic buttons ON the trunk itself the trunk opens and closes just fine.
If anybody knows how to fix these issues/what I need to do to fix them please let me know.
Thank you!
The windows may need resetting.
to do that hold the button to roll the window up. When the window reaches the top, continue to hold the button for ten seconds. Press the button to roll the window down. When it reaches to bottom, hold the button for ten seconds.
The window may have excessive friction between the window and the seal.
Some folks have reported good results by using a silicone grease on the edge of the glass. Try hard to avoid getting any silicone on the car's finish.
There is a setting for the amount that the trunk lid opens. I don't have that option, so I don't know how to set it.
Search is your friend. Start at the threads in light blue at the top of the W220 Forum Home page, where it says START HERE. You should find help for each of your problems there.
If no keyless go, does the car lock/unlock with the buttons on the dash?
Another way to test the key fob is to stand near the car (about 2-3 feet away) and hold the unlock button on the key down without releasing it. If it is working properly the sunroof and windows should all open. Also, if you hold the lock button down after the windows and sunroof are open they should all close. You should be able to do this from either side of the car.
One simple question - are the batteries in the key fob inserted properly?
