ENGINE VIBRATION AT IDLE
Could it be the coil packs as well? I am unsure on what the heck is going on?
Cheers,
Jeff
Cheers,
Jeff
The best way to use Techron or SeaFoam is with short-trip driving. This allows you to run the engine enough to get it warm, then let the fuel/Techron mix to sit in the injector as it cools. The repeated hot/cold cycles and extended soaking times over a week or two are much more effective than running a tank-full thru in a few hours on a long trip.
Poor sea-foam in intake very slowly at idle and let the engine eventually flood and stop. Wait 15-20 mins, it will be hard to start and will throw a few emission codes. Reset those, and drive it hard. This will remove all the carbon build-up on the valves. Do this somewhere remote as it creates so much white smoke people will think there's a fire. lol
Use a can sea-foam in the gas tank for 3 fill-ups. then every oil change, poor seafoam in the gas tank. Ensure you have a new fuel filter before doing this.
There are plenty of youtube vids on poring seafoam in the intake.
Car should idle better, have more pull, and you should get better gas.
If this doent fix the rough idle, then do a compression test. If you have a cylinder down, typically cylinder 7 or 8, then poor some ATF fluid onto the piston and let it sit overnight to free the stuck rings.
