New headlights
The contact points are different on the halogen cars compared to the HID cars. Therefore, you must cut all the wires and directly wire them to the correct positions.
The wiring is correct. If it wasn't, then neither of them would work. They are made like this. You can even see this feature on the SPEC D installation video where they demo the headlights working. It's actually more convenient and doesn't bother me in the slightest.
I'll post a few more pictures later with all the different lights on.
Thank you very much for the updates (ps. your car looks AMAZING)
I will soon be getting these for my 2000 S500 with factory HIDs. As I understood from your posts I will need to "manually" wire the 6 pin from these to the 6 pin wire from the car, am I correct?
Also, could please show us some pictures of how you did the wiring (i.e. which wire connects to which pin)?
One last question, is the aftermarket HIDs still working fine (eg. no melting, flickering, ect)? Can I use any 35w HID kit (H6 bulb) with them and H1 LED "bulb?
Once again, thank you so much, for giving me and many others the chance of having a new amazing look for our cars
Many thanks, Nick
As I understood from reading Alex's posts he installed an aftermarket HID (Xenon) kit.
The lights are supplied with STANDARD H6 and H1 Halogen bulbs.
Finally, if you plan on installing an aftermarket HID kit make sure:
- They are 35w Not 50w otherwise, the housing will melt
- They come with canbus, otherwise, you will get an error on your dashboard (and they may even flicker, or not work entirely)
- Your factory Xenon will NOT fit because they are D1S or D2S and possibly are 50w
I wish you the best of luck!
