How common do SAMS fail on these cars?
Recently I've been working on my S430 narrowing it all down to SAM problems in the front left and rear
There seems to be a lot of wrong diagnostic on cars due to SAMS going out causing other functions of the car behave strangely.
I've heard these cars have water design problems but aside from this...
Are this "signal routers" common to fail ? How much do they typically last?
I know if the damage is done. The sam needs replacement. I will change it soon. But im analyzing what might be the root of all this evil...
I inspected front driverside and rear sam's the front sam looked okay but after taking a look at the diagrams and comparing the systems that work intermittently on my car that sam might be gone (since when I bought the car it had cables jumped instead of fuses.........
) Its going to be replaced. After looking at the rear nothing looked suspicious and I found no traces of water or corrosion.
The only part that im having problems with corrosion is where the battery is located and the fuselink near that area that I had to replace (replaced the fuses inside the junction box).
There is a big problem in the motor trade in that mechanical engineers/fitters do not understand electronics, and why should they its a field all on its own.
A DAS/SDS system clearly identifies problems with a SAM.
If an operator doesn't know how to use it, change operators.
