2003 radio swap with 2006 radio
For those who have 2003 SL500 Bose audio system how does it sound?
Mine seem to be lacking in base (I have it set to 10) still weak.
I compared it to my non-Bose system from 2005 Lexus - Lexus has the "Thump/Base".
A Bose system is known for great sounds (highs and lows). This one does not have it.
Any suggestion to get the sound quality better is welcome.
BTW - Does the Bose system on SL500 come with a sub-woofer?
The 2003 S500 Bose system does have a subwoofer mounted under the rear window. Bass is adequate - I keep mine on zero or +one.
[QUO=JojoManigbas;8326070]A new owner of 2003 SL500.
BTW - Does the Bose system on SL500 come with a sub-woofer?[/QUOTE]
The DB2 versions uses the CAN to communicate between components to turn them on/off, pass signals and data, etc at rather slow data rates. The MOST systems have much faster digital data rates (and are not compatible with analog versions.) You would have to rewire the entire system to install a MOST system in a car equipped with DB2 systems, as well as changing all the systems components. It is not a trivial undertaking like simply swapping the 'head unit.'
