2002 w220 s500
Old Mar 2, 2016 | 03:35 PM
grggowens's Avatar
s 500
2002 w220 s500
I have a 2002 s500 w220...engine check light is on esp defective display on and speedometer needle not working but all the other gauges work and abs light on and airmatic visit workshop on..and transmission wont shift out of first gear
Old Mar 3, 2016 | 12:08 AM
tusabes's Avatar
Mercedes
But the car runs and drives , in first gear and reverse ?
Old Mar 3, 2016 | 07:17 AM
grggowens's Avatar
s 500
Yes
Old Mar 3, 2016 | 07:18 AM
grggowens's Avatar
s 500
The day before car was driving fine...then boom
Old Mar 3, 2016 | 07:49 AM
wallyp's Avatar
2003 S500 2007 GL450
You might try disconnecting the battery for a few minutes to see if any of the error messages disappear. If not, the best thing to do is probably try to find a dependable shop near you that has the Mercedes STAR/DAS system and have them pull and write down all of the error codes. There will usually be a charge for doing this.
You might have a wheel speed sensor that is dirty or faulty, or has a faulty connection.
Open the right SAM (under the hood, below the right corner of the windshield) and check each of the wire harnesses for any traces of ATF (oil on the wires). If you find an oily harness, one of your problems might be that ATF has wicked up the harness from the leaking adapter plug, and has filled your Transmission Control Module. This can eventually cause the transmission to malfunction. You can sometimes cure the problem by pulling the small black box attached to the oily harness from the SAM, opening it and cleaning it thoroughly with brake cleaner.
Old Mar 3, 2016 | 07:59 AM
grggowens's Avatar
s 500
Ok.thnx..i disconnect the battery a couple of times before but no avail..my car was acting up two weeks before this happen..car was shifting hard and check engine lightcame on ..i disconnect battery and check engine went off and car shifted so smoothly and the over night this happens
Old Mar 4, 2016 | 03:40 PM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
How old is your battery?
Old Mar 4, 2016 | 05:05 PM
tusabes's Avatar
Mercedes
Agreed it may be a leaky transmission plug damaging your electronics
Originally Posted by tusabes
How to change transmission electrical plug
(Fluid leaks into wiring)
Mercedes transmission 722.6 electronic connector leak - YouTube
Old Mar 5, 2016 | 07:44 AM
grggowens's Avatar
s 500
Battery is almost a year old, but i notice that my four way flasher button no working,my up and down lift button not working and my esp button not working and my door lock and unlock button not working on dash board
Old Mar 5, 2016 | 02:19 PM
Russell Ormerod's Avatar
not a merc
Oil in harness won't cause your issue. Check esp for faults that's why the speedo does not work. No road speed from esp will cause gearbox to run in limp mode. Check fuses for esp too
Old Mar 6, 2016 | 08:38 AM
wallyp's Avatar
My first "internet guess" is that one of the wheel speed sensors is not furnishing speed input to the other systems.
