ESP ABS BAS Warning after shock replacement
After shock replacement I connect battery and reset it steering wheels and everything good when i start driving after 1 min BAS ESP ABS come back and steering wheel is misaligned car drive straight and steering wheel is angled.speedo cruise brake lights and everything work only steering is weird.
Everytime when i start car is fine and 1 min drive same messages come back.
What could be wrong ? I'M reading about wheel speed sensor(which one)? could be just fuse? Do i need replace tie rod ends and get alligment done?
Thank you for any suggestions or help
Is an electrical sensor was unplugged and not fully plugged back in or the connection was dirty . Go back and redo all electrical connections you unplugged
Two of the more likely spots for trouble are the connectors for the front struts and level sensors. The sensor connectors are a matched pair, and the best way to hook them up is to hold the two connectors tightly aligned side-by-side and insert them firmly into the socket on the fender well, ensuring that they snap into place.
It is important that the suspension joints with rubber bushings are tightened only with the car's weight on the wheels - not with the wheels hanging in the air.
If you did not change or remove the tie rods, nor remove the steering wheel, I have no idea what is wrong with the steering alignment. It does sound like a good idea to change the tie rods and get a complete alignment done by someone who is very familiar with the W220 - not just the cheapest alignment shop.
I also did actual value on steering angle sensor and number was changing when i turn steering wheel.
When car is park and running i do t get warning when i drive warnning come in 1min. Also when i turn while driving steering wheel is not returning back by self. I checked all wheels shock connectors and all is plug good.
Could be steering angle sensor? Could be alligment? Where should i start? Thank you
Today I order new tie rods inner and outer and also steering angle sensor.
Could my wheels be misallignent? Can i do alligment my self? Can be my power steering pump weak?thank you for any advice or suggestion
1) Yes my opinion is your wheels are misaligned. I advise you to check what went wrong, changing struts with arnott did not make any problem with my alignment. I mean check if any possible wrong installation for your safety.
2) Yes you can do yourself, I paid a lot for alignment last year but now I can do it myself mechanically within the tolerances, only it is time consuming, It takes my whole day. you just compare your off-day rate with the workshop rate.
3) If your steering wheel is not turning back straight, check also your caster angle, I had this issue when I did wrong installation with adjustable bolts on torque strut.
4) I don't think that these are related with your steering pump but why not to inspect it? remove your serpentine belt and check for any movement, try to rotate puller with your hand and check for any noise. Check the fluid level and color.
first look under, you may notice the wheels are not looking straight.
