2001 s500 got ECU stolen now what
Old 04-15-2016, 11:23 PM
MbNeedshelp's Avatar
1994 w140 s350d
Thumbs down 2001 s500 got ECU stolen now what
The ECU in my beautiful 2001 S500 was stolen. I have another 2001 s500 in bad shape, that I removed the ecu and what I thought is the immobilizer (where the key fits in and turns) and used the key that went with it, swapped it all out to try and start nicer car that had the ECU stolen and the key turns, but none of the normal lights come on in the instrument cluster and car wont start... What am I missing? I was told swapping all three parts (Key "trasnsponder", immobilizer and ecu as a set) would start my other car. Please help, my bad S500 basically is a parts car being it has so many problems, but it starts and drives.
Please Help.
Old 04-16-2016, 02:12 AM
tusabes's Avatar
Mercedes
You need to change the shifter too from the donor car
Ecu , key , shifter , and ignition switch must all be swapped as a matched set
Old 04-16-2016, 11:45 PM
1994 w140 s350d
Thank you so much for responding. Can you instruct me in where and how to change out the shifter ?
Old 04-16-2016, 11:58 PM
1994 w140 s350d
Do you mean the actual shifter, where you put in gear, or the steering column module ?
Old 04-17-2016, 09:11 PM
tusabes's Avatar
Mercedes
The actual shifter box in the center console
There's tons of YouTube videos how to change it
Old 05-03-2016, 11:32 AM
1994 w140 s350d
Thumbs down stolen ECU
I ended up taking the car the dealer. I was told by a MB shop they tried that and as they put it "it didn't turn so well" Thank you for your help.
Old 05-09-2016, 04:51 PM
1994 w140 s350d
Angry dealer can't get car to start
I had to purchase a new ecu and now the dealer can not get the ignition to power up. they are telling me that it keeps blowing fuses in the fwd and rear fuse boxes. they also said it seems the car has water intrusion which is why the fuses keep blowing. now they are telling me the key will not even turn , which it was when i took it there. please anyone help. dont know what to do now
Old 05-09-2016, 04:56 PM
1994 w140 s350d
Angry parts car
I initially installed an ecu , key switch with matching key from a parts car i have but it would not have any action in the instrument cluster. the cluster would come on when i opened the car so I'm very confused !
Old 05-09-2016, 08:51 PM
tusabes's Avatar
Mercedes
If it's a water damaged car it will likely never function right unless you get all SAM and wiring harnesses From a good donor car
Old 05-09-2016, 09:51 PM
Jack_88's Avatar
2018 C300
What made them suspect water intrusion? Was there damp or visible water damage? Germans love putting modules down low, so a lot is susceptible to pooling water.
Old 05-10-2016, 08:11 AM
1994 w140 s350d
Thumbs down water evidence
I inspected the car carefully and found no evidence of water, and one thing the dealer said puzzled me, the key always turned and now they are telling me the key will not turn ? I don't want think they are trying to rip me off but dang there's jut too many issues all of a sudden !
Old 05-10-2016, 04:10 PM
Jack_88's Avatar
2018 C300
I had a Chrysler dealer sabotage my car and run me about $2000 by the time the dust settled. I couldn't prove it, they'd have just said I caused the damage I found(screwdriver shaped hole in the motor side of the radiator.) So, I would say at least some suspicion is healthy unless you know the dealer well. I've also heard of dealers breaking things on accident and saying it was a preexisting condition to try to dodge liability.
Old 05-16-2016, 09:31 AM
1994 w140 s350d
Thumbs down Rear SAM damage
Seems as though the car has been in a flood ? I have not seen it since the dealer gave me the bad news. I asked them to stop all work and asked them to push it out so I could have it towed it home where I have a "donor" car waiting to be cannibalized.
Old 05-18-2016, 02:42 AM
tusabes's Avatar
Mercedes
the car was not driven in a flood ,but a simple rainfall can cause the interior electronics to get flooded due to a defect
See the First post here , it's a very common problem and was the subject of a class action lawsuit but the time to file a claim is now over
https://mbworld.org/forums/s-class-w...ins-clean.html
Old 05-20-2016, 01:40 AM
1994 w140 s350d
Thumbs down Rain Not a Flood
Thank you so much for the heads up. Can I use a the good dry units from a donor car to replace the wet ones without any worries abt VIN # compatibility uses ?
Old 05-20-2016, 04:26 AM
tusabes's Avatar
Mercedes
Yes you can as long as they are the same part numbers
You should be using every part from the donor car - ecu key shifter ignition switch , front and rear SAMs and wiring harness running along passenger floor
They are likely all damaged in the water damaged car and everything needs to be swapped over
Quick Reply: 2001 s500 got ECU stolen now what
