Newbie S500
All the repairs that you have listed in your post have been covered either on this forum or Benzworld.
An up-dated encyclopedia with most repairs can be found here on Benzworld with PDF files to download with WIS instructions and torque values. You will eventually want to get your own copy of the MB WIS/EPC for all future repair work. See my post here for what I did. I couldn't own a Mercedes without it. The cost of using the dealer or indy would be prohibitive.
If you should get stuck or can't find what you are looking for, post your query on this forum or introduce yourself on Benzworld and start a thread there.
Good luck,
Bob
Thank you for the quick response. I have literally devoured the links in the encyclopedia you pointed me to. I simply cannot find a page of torque recommendations for putting the suspension back together. It seems each chassis has a different recommendation for each nut and I am not comfortable using the W204 specs on my w220. Just thought someone might have a copy of the page in the WIS (whatever that stands for, I am guessing a service manual from Mercedes) that gives all the front suspension torque specs for the W220. The encyclopedia page by the way rocks!!!
I'm attaching a few PDF's from the WIS that I have saved to get you started.
Please note, suspension components must be final torqued in the "ready to drive position". You can lower the car down onto ramps to fully load the suspension then crawl under to finally set the torque for the control arms etc. This will be noted in the instructions.
Good luck,
Bob
