Failed Trunk Assist
I have an '05 S500 with a defective trunk assist. It does unlock but doesn't lift. Also, the trunk close button doesn't work. My plan is to check fuses, then check the hydraulic fluid in the pump. Am I on the right path??
Some just have power unlock
You can tell the difference if the lid has gas struts or springs . Lids with gas struts have the power trunk lift/power close
Lids with springs only have power unlock
Check power to the pump if it's not out of fluid. My car leaks profusely from the ram seals, which are not serviceable according to MB. Rather than buy a new pump/ram unit, I'm gonna pull it and send to TopHydraulicsInc for a rebuild.
I had trunk lid problems and it was related to the hinges getting stiff from lack of lube. Incomplete opening is a sign of this.
I just thought I would throw that in here as old threads still get looked up from google.
