Got problems with door lock/soft close/air in seats
Recently got problems with soft close not working, door locks and seat air, head couch air at the same time, anyone got some ideas? vaccum pump, fuse, leakage?
If that isn't the problem, time to check the PSE pump in the forward left corner of the trunk.
Is it the same fuse system from 99 to 200X? Or did they change it... any different from US to EU?
Thanks in advance
I went ahead pulled the pump out and the motor was pretty much toast. I can barely get the impeller to spin. There are some signs of the plastic board melting a bit too, but I did a pressure test on it and it seems to be okay.
I'm half way through the process of changing out the motor, and adding a heat sink copper coil to the hot side. Hopefully both those changes will get me up and running again soon.
