S600 oil change question
Old Mar 31, 2017 | 10:23 PM
PeterS.'s Avatar
S600
I'm planning to drive the 2003 s600 5.5 v12 up driving ramps to do the oil change. Does the car need to be level for the oil to come out? And where is the drain plug? Thanks !!
Old Apr 1, 2017 | 08:48 AM
Welwynnick's Avatar
2006 S600
The drain plug is at the rear of the lowest part of the sump, and just in front of the subframe cross-member. Therefore if you're on ramps, the oil will run backwards towards the drain.
However, it will also run back towards the rear of the engine, and I don't think you will get all the oil out using ramps. I think it's best to keep the car level.
I don't think I explained that very well. Was that clear?
Nick
Old Apr 1, 2017 | 10:06 AM
PeterS.'s Avatar
S600
Nick
I understand why the car needs to be level. But can you explain more on the drain plug location, thank you.
Old Apr 1, 2017 | 05:36 PM
DrDoe's Avatar
W212 E350; W166 GLC300; W164 ML550; W164 ML63; W221 S65; W220 S430; Escalade ESV
I'd been in your shoes. It sounds stupid but I have no idea where things are or what their functions. My advice to you is to get under the car and take a look around. At the side of the bottom oil pan you will see a shiny silver and gold plug. You can't miss it.
I hope that you bought the silver and gold things before starting the job. Good luck to you!
Old Apr 5, 2017 | 02:56 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
You'll need to remove the center splash shield to see the sump. It's 4 M8x30 bolts with washers. Once removed, you'll see the oil pan and drain plug.
