Ball Joints - Quoted $650 +tax?
Just went to a shop in San Bruno, CA.
They gave me a quick quote for ball joints repair to be $650 parts and labor + tax. I forgot to ask them what parts they were using. And I'm assuming they didn't include anything else in the quote such as control arms.
Does anyone have the part numbers for the ball joints and control arms? I'm trying to fix the famous squeaking issue coming from the front.
I believe it's universal. The control arms are vehicle specific depending on suspension options.
Whats the name of the shop? I'm local and know most of the shops around here
All that aside, a cursory look at book time for installing the Lower Steering knuckle joint left and right is 4.2 hours.
That includes R&I the knuckle and joint.
With all due respect to DrDoe, part number 2113230068 (#47) is not the correct part number for the lower joint. It is the joint pressed into the Traverse or Spring control arm for the Anti-Sway bar. The correct part number is 2203330727 (#10). List price on that part is $104 but can be gotten for < $75.
This is based on my '01 W220 rear wheel drive.
With all due respect to DrDoe, part number 2113230068 is not the correct part number for the lower joint. It is the joint pressed into the Traverse or Spring control arm for the Anti-Sway bar. The correct part number is 2203330727. List price on that part is $104 but can be gotten for < $75.
i'm asking for a 2004 s500 with Sport AMG pkg.
At this moment, I didn't get a paper quote. The guy gave me a verbal quote for $650 for the ball joints.
Ball joint front lower - #211 330 04 35 $35
Total cost to me was $375 for a 2005 S55 in San Jose. It fixed the squeaky noise coming from the front right.
He's telling me the following:
There's 2 Front Lower Control Arm on each side (driver & passenger side) both needs to be replaced. He's stating that there are cracks in the plastic pieces and that I should replace all 4 of these. He says that the parts are $700. The labor to install them are $600. He also says that because my car is 90k miles, I should replace the air suspensions int he front as well. Is this true? He's stating that if I don't replace the air suspensions and only do the control arm, the squeak will come back after a year when the suspension starts failing.
european car service is an honest shop. Ask them if they're $650 estimate will guarantee no squeaks
The squeak comes from ball joints/control arms . Your airmatic struts are not going to cause the squeak over bumps, not even a year from now -so that second recommendation concerns me that they are recommending extra work .
Of course it's nice to change everything, at this age , but changing working struts isn't necessary or cost effective
I would run away from that shop.
If you are entertaining the idea of DIY, I highly suggest that you replace all of your front end arms & ball joints at once.
I've done this for 2 cars & piece-by-piece is a horrible waste of time. You will save a ton of time if you remove the steering knuckle & all attached arms. It's soooo much easier to get the ball joints out of a steering knuckle, & pressed back in, on a bench than on the car.
If you call Autohausaz, they'll work out a deal for a full package that was less than $450 for all parts to me. It was probably $525 to do piece-by-piece. You'll need a ball joint press & separator plus male & female TORX wrenches/sockets (not sure if there's a technical name for those). Jack stands & a big *** hammer are the only other things I can think you'll want outside of a regular toolkit.
Doing an arm/joint at a time will take at least 10 hours. 3 hours total work if you remove the steering knuckle & work from a bench plus you'll have a like new ride.
