Front Strut Dampener missing?
Incident: Hit a road debris early AM. The side affected was the front left. Felt something detached as I heard it from my wheel well and travelled on to the left underside of the car. Saw grease splatter. Initial impression was road debris and cv boot got torn, hence the grease splatter.
Went to the dealer to have a diagnosis of the clunking noise coming from the left front and found left front ball joint has play. So they recommended replacing the left front lower control arm. Also, now that my CV inner boot is torn, so okay I'm replacing the cv shaft too. I also mentioned that I have some vibrating feedback from the steering wheel when going over road irregularities and bumps. On the report they said that my left front strut dampener is missing! Now they said I have to replace both left and right airstruts. They quoted me $7000+ taxes.
Where can I find this strut dampener and is this something i can replace without going all out on new/rebuilt struts?
Is it this one? Y51 on the diagram:
Help...
The dampener shown is part of the Airmatic strut, and not normally replaced separately - but it doesn't usually fall off of the strut, either.
The dealer's quote is ridiculous.
Assuming that you are being told the truth, you now have several choices:
- Go DIY, and install a rebuilt strut - one Saturday's work and less than $500.
- Find an honest and competent independent garage whose owner is familiar with W220 maintenance and repair, and throw yourself upon his mercy.
- Find a more honest dealer and try again.
- Let your present dealer do the repairs, and be sure to get the sign for your forehead.
They're nuts. That's like a good downpayment for a new car.
You can find numerous write-ups and videos on replacing the axle or the boot, and on replacing the strut. Do your homework - there are several tips and tricks that can save you a lot of frustration.
If you replace the strut, you will be able to check the wear in the ball joint pretty easily. Given the dealer's estimates so far, I think that I would like to check this myself.
If you replace only the strut and the boot or axle, you probably don't have to have an alignment - but it might be a good thing to do after all repairs/replacements are complete
This what it looks like from the right front side. That little cylindrical item (on the left aide of the picture) attached to the strut. Its there.
Now on the left front, its missing.
This is what the dealer meant about my missing dampener. Explains why i have oil splatter on my wheel well. So no choice but to replace the whole strut.
Pretty unusual incident. It also was troubling to hear that Arnott apparently can't supply rebuilt front struts any more.
Here in Ontario, I heard about exoparts.com and they're local. One new strut is 725$ CAD including an MBworld member discount.
Anyway, it seems like I won't do a DIY on this. I'm not just comfortable doing it myself. Plus I don't have the proper tools especially if I f*ck something up.
Forum members can use code MBSAVE10 to save up to 10%* off the retail prices on Arnott® replacement air suspension products for your Mercedes-Benz®. You can place your order online at the Arnott Web Store or by calling Arnott Customer Support at 1-800-251-8993 X 804 Mon – Friday from 8:00 AM to 7:00 PM ET. Orders placed by 2:30 ET are typically shipped out the same day. *Max savings $75 per order, not valid with any other offer or on compressors, shipping, taxes or core deposits (if any).
The Arnott designed new struts are built from the ground up with all new components including a new shock custom valved to ride somewhere between the Comfort and Sport settings. They still offer the luxury of a true air ride and auto leveling but at a much better price than the dealer struts. No core deposits either.
Thank you for the reply and the clarifications.
One additional question - what should we expect from you if one of our remanufactured lifetime warranted struts fails?
Arnott® offers a Limited Lifetime Warranty for European Union and North American customers on all Air Springs, new and remanufactured Strut and Shock Assemblies, Coil Spring Conversion Kits and Air Suspension Compressors. Orders from elsewhere come with a Limited Two-Year Warranty. Arnott’s warranty on dryers and accessories is 1-Year. Arnott’s warranty is nontransferable. If a part is defective, Arnott will either replace or repair that part, as long as it is within the warranty period and proof of purchase is provided. Arnott offers a 30-Day Warranty for parts used in commercial vehicles. Improper use or installation is not a manufacturer’s defect. To read the full warranty: http://www.arnottindustries.com/warranty
As for the shock, does it still work? Is your side down? Maybe I'm missing something but if it's just the harness that got detached I would try to find a way to mount it back up. Zip ties?
If it ain't broke, don't fix it.
