Instrument cluster tech question
s430
I recently had my MY00 s430 instrument cluster replaced under warranty with a MY04 cluster. As a result I no longer have a screen for gas tank content. I asked the service department and they say it is a feature that is no longer available on current w220 sedans. Anyone out there know if this is true?
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I think this is being removed from newer cars, but I am not sure.
Do you still have use of your steering wheel controls?
-s-
-s-
Originally posted by jahummer
Of course, this was done by the dealer under warranty.
-s-
'05 A4 1.8TQM6
I'm having fuel gauge problems (I posted a little while on this) where it drops about a 1/4 " after driving for a few minutes right after filling up. I'm looking at the readout in the MFD and the gallon's drop by a little bit, normal i guess. Then the fuel gauge will start moving up again...which isn't normal.
So I'm guessing it's the fuel sending unit, but if they have to replace the cluster with a updated one, then I won't have that fuel tank readout anymore with the fuel left/miles left/MPG/etc?
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Originally posted by awiner
The screen you are speaking of was dropped in the 2003 model. 2002 was the last year that had that feature.
I have replaced IC under warranty about a month ago and still have gas tank content screen as usual.
Yet I gained that missing digital speed redout
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
awiner, are you sure about that the tank contect screen was is no longer available?
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Yes, if you have a newer cluster the tank content is no longer available. It may simply be in the programming however.
I know my 2001 had this option and my 2003 does not.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
My 3-week old IC does have this option...
