Loud cracking sound when opening/closing the door
Old Sep 21, 2018 | 08:10 AM
STRGLZ's Avatar
Mercedes S430 2003
Hi there.
My driver's door makes a very loud cracking sound when opening and closing it. I haven't found any solution yet because it's not the typical squeaking/creaking sound that you would fix with some kind of lubricant (I tried). I asked the opinion of a mechanic and his only answer was "It's something inside the door", so I'm clueless.
Here's what I'm talking about : https://youtu.be/gRquJ6muGeU
It doesn't sound very loud on the video, but I could easily wake up my neighbourhood when I get home at night. (Fortunately no one complained yet)
Has anyone any clue about what it can be ?
Old Sep 21, 2018 | 10:07 PM
wallyp's Avatar
2003 S500 2007 GL450
One of the most common causes for this type of noise is the door check assembly - the flat, black rod from the front edge of the door to the frame at the door opening. So far, my attempts to cure the noise with lubricant have been failures, and replacement was the only repair that worked.
Old Sep 21, 2018 | 10:12 PM
STRGLZ's Avatar
Mercedes S430 2003
You mean replacing the whole door assembly ? How much does that cost ? Do you have a link to the said part ?
Old Sep 21, 2018 | 11:13 PM
tusabes's Avatar
Mercedes
Just replacing the black strap you see in the door
Old Sep 22, 2018 | 06:15 AM
STRGLZ's Avatar
Mercedes S430 2003
Oh I see ! It would make sense if that is the faulty part because I unbolted it once to try to locate the problem and the door stopped cracking but didn't hold. Do you have to open the interior of the door to replace the strap ?
Old Sep 22, 2018 | 10:28 PM
wallyp's Avatar
Yes.
Old Sep 28, 2018 | 11:24 AM
OhYou_'s Avatar
s430
To be clear, we are talking about the Door check assembly, PN: 2207200016 (Drivers)?
I've just ignored mine, but for $45, seems worth it.
Old Sep 28, 2018 | 11:30 AM
STRGLZ's Avatar
Mercedes S430 2003
https://www.ebay.com/itm/Mercedes-W220-S350-S430-S500-Door-Stop-Front-Genuine-220-720-00-16/150933373768?hash=item2324548348:g:xNAAAOSwZ~lZumF U that's the part.
And yeah it's pretty much worth it since it's kind of embarassing to get out of your car when the door makes such a noise.
Old Nov 27, 2019 | 08:44 AM
Flydutch's Avatar
Merc S55 AMG Kompressor 2003 & S320 1999
Did any of you guys opened the thing up after having replaced it with a new one and checked how that mechanism works. I hate replacing parts that simply need a service, It sounds like spring loaded restrainers which have dampers which are gone soft and a insertion of a rubber nay simply "Revitalize" the dampers.
Old Nov 27, 2019 | 01:47 PM
scotterikson's Avatar
01 clk430, 05 e500 4matic
I didn't tear into the one I replaced recently, but a quick visual didn't reveal any obvious problems. Threw it out and went on with life. Think I spent $21 on a knockoff amazon part, no issues yet
Old Nov 28, 2019 | 02:47 PM
DK14's Avatar
W220, 320, CDI, 2003
It’s the door stop.
Old Nov 29, 2019 | 09:24 AM
Kebowers47's Avatar
001 s600, 94 sl600
What happens is lack of lubrication during 'service' and a groove wears in the strap where it rests when the door is closed, causing the 'snap' U gotta remove it from inside the door.
