Engine vibraion, but different..
Old Aug 10, 2019 | 04:04 PM
Kamil Puchala's Avatar
w220 S350
Hi!
I have a problem with my w220 S350.
The engine is vibrating and making some noise in the cabin from 1500 to approx 4500rpm, on every gear and in neutral.
Ive changed the hydro clutch, and the harmonic ballancer. The result is absolutely no vib at iddle and between 3000 and 3500rpm, but the main vibrations are still present.
One very interresting observation - when i drive the car trough a bigger puddle, and the water splash enters the engine bay the car runs silky smooth for a few seconds till the water dryes out.
Im struggling wit this since approx one year and i have no clue what can it be, maybe the belt tensioner is faulty.. I dont know..
If u have some ideas please let me know, thanks!
Old Aug 11, 2019 | 01:37 AM
tusabes's Avatar
Mercedes
Originally Posted by Kamil Puchala
Hi!
Belt tensioner
Old Aug 11, 2019 | 10:13 AM
Kebowers47's Avatar
001 s600, 94 sl600
Check /replace the engine mounts and transmission rear mount. Check and replace if broken all the exhaust system mounts.
Old Aug 11, 2019 | 01:04 PM
SLcharge's Avatar
09 SL500, 03 E320 CDI Wagon
Replace the belt and belt tensioner.
Old Aug 13, 2019 | 09:01 AM
w220 S350
I've changed the belt tensioner, installed a new belt and idler pulley - still the same.
My mechanic checked the engine, transmission and exhaust mounts - they are ok.
It's raining a lot today, and again, when i drive trough a deeper puddle the whole vibration stops - engine runs silky smooth.
Old Aug 13, 2019 | 10:05 AM
wallyp's Avatar
2003 S500 2007 GL450
It is pretty easy to slip the serpentine belt off of the pulleys, and it is safe to run the engine for a few minutes without the belt. Slip it off and run the engine up to where you normally feel the vibrations. If the engine is now smooth, the problem is with one of the belt-driven devices - alternator, power steering, AC compressor, water pump. If the vibration is still there, it is not in one of the belt-driven devices.
Old Aug 13, 2019 | 10:13 AM
SLcharge's Avatar
You are sure the noise comes from the engine ?
You don't mention if the vibrations are same with hot and cold engine.
Driving through water, the water not only enters the engine bay but also cools down the entire exhaust. Being thin walled, it heats up again within a few seconds.
If the exhaust have "body" contact somewhere along it's path, it can make a lot of noise, sometimes difficult to point out.
A warm exhaust expands, a cold one retracts ( water ??)
Old Aug 13, 2019 | 10:18 AM
SLcharge's Avatar
Good advise.
Old Feb 13, 2025 | 07:41 PM
Jimson.w220's Avatar
w220 s500
Hi all, i realise this is an older post but by chance did you find out what was causing the vibrations??
Ive got the exact same symptoms with my s500.
Any help would be appreciated.
James
Old Feb 14, 2025 | 04:57 PM
Fried Chicken's Avatar
2005 S500 Designo
I swear these cars have inexplicable vibrations built in from the factory.
Chased down the same issue. The trans mount cannot checked by eye, and will look good even though it has failed, but more likely than not it's a whole slew of problems adding up.
Engine mounts, harmonic balancer, trans mount, exhaust mounts, strut mounts, other suspension components, everything.
Old Feb 14, 2025 | 05:17 PM
w220 s500
Hi,
Well its somewhere to start, unfortunately its going to be one of those cross it off the list and hope for the best.
Thank you for responding. Appreciate it.
Old Feb 14, 2025 | 05:39 PM
2005 S500 Designo
Originally Posted by Jimson.w220
Hi,
Could also throw ignition coils onto that list; rubber exhaust mounts, guibo's front and rear, center support bearing, rear subframe bushings...
And like I said it could be all of these mixed together. These cars weren't designed/built properly
Old Feb 15, 2025 | 02:34 AM
tusabes's Avatar
Mercedes
Trans mount is cheapest , easiest and most common failure
Old Feb 15, 2025 | 02:55 AM
w220 s500
Just thinking about my cars issue. It vibrates even in park. When not in gear and just revving to 2k and more, I get a vibration which can be felt next to my leg and through the floor. Does that narrow it down at all?
Old Feb 15, 2025 | 11:52 AM
tusabes's Avatar
Mercedes
First do transmission mount then engine mounts
Old Feb 15, 2025 | 11:53 AM
w220 s500
Legend. I'll start there.
Thanks for the advice.
Old Feb 16, 2025 | 10:10 AM
2005 S500 Designo
The engine mount job is not for the feint of heart.
Old Feb 17, 2025 | 02:41 PM
e350forme's Avatar
fleet
because of the exhaust?
Old Feb 17, 2025 | 08:14 PM
W205C43PFL's Avatar
Especially for 4MATIC vehicles.
Old Feb 17, 2025 | 08:15 PM
W205C43PFL's Avatar
I'm not saying OP has a 4MATIC but I mean in general.
Old Mar 14, 2025 | 04:46 PM
w220 s500
Evening guys,
Just an update. Had the gearbox mount replaced yesterday and the vibration has totally gone she drives like a dream now. Thanks for the advice, it was much appreciated.
Old Mar 14, 2025 | 04:56 PM
2005 S500 Designo
Evening guys,
Enjoy!
Old Mar 14, 2025 | 04:58 PM
W205C43PFL's Avatar
Evening guys,
Thanks for the update, glad to hear.
