Question about replacing s430 engine?
Old Aug 27, 2019 | 03:46 AM
nerdboy's Avatar
s430
I currently have an s430 with 214k miles and was interested in doing a motor swap with a motor with 93k miles. If I swap the motor over does the ECU have to be reflashed or can it run with the replacement motor?
Old Aug 27, 2019 | 06:52 AM
Welwynnick's Avatar
2006 S600
The ECU is tied to your car's transmission selector, electronic ignition switch and the key . It's part of the security.
You should use the existing ECU, but be aware that it will have to re-adapt to the new engine.
Nick
Old Aug 27, 2019 | 10:14 AM
wallyp's Avatar
2003 S500 2007 GL450
Is there a reason to swap the engine?
Old Aug 27, 2019 | 12:05 PM
tusabes's Avatar
Mercedes
Unless your engine has problems there’s. No real reason to do this . These engines easily last over 300,000 miles.
It would be better to swap the transmission as they fail around your mileage .
