2000 S430 No Start
Old Oct 23, 2019 | 06:32 PM
garvan62's Avatar
2000 S430
2000 S430 No Start
Starting problem, key turns on but does not turnover, does not even click, dash lights come when the is key is in the on position, on my 2000 mercedes S430 replaced starter relay and battery in fob and car battery is good had tested at auto zone, jumped at starter relay with jumper wire starter turned over, but no start, the shifter will shift to neutral, but no turn over not even a click from starter. Wife drove and turned off at home and nothing next morning.
Old Oct 23, 2019 | 10:47 PM
tusabes's Avatar
Mercedes
first check the main fuses under passenger floor aluminum panel
if that isn’t it
Youll need a matched set of key , ignition switch shifter and Ecu taken from a donor car .
Old Oct 24, 2019 | 09:29 AM
garvan62's Avatar
2000 S430
Thank you I will check the main fuse
Old Oct 26, 2019 | 01:33 PM
garvan62's Avatar
2000 S430
Tested fuses under carpet and read same as test leads, will test key fobs received three fobs with car never used the other two will install new batteries and check. Thank You!
Old Oct 26, 2019 | 02:24 PM
tusabes's Avatar
Mercedes
The batteries in the key fobs Make no difference for starting the batteries only power the remote lock and unlock
a key can have dead batteries and still start the car
Old Oct 26, 2019 | 03:50 PM
garvan62's Avatar
2000 S430
Thank You, I am sorry, I do not understand, the key fobs can start the car without batteries.
Old Oct 27, 2019 | 12:28 AM
tusabes's Avatar
Mercedes
The key fobs do not need any batteries to be able to start the car . The batteries in the key fob are only for remote lock and unlock function
Old Oct 27, 2019 | 10:23 AM
wallyp's Avatar
2003 S500 2007 GL450
The link between the ignition and the key fob is done thru inductive coils, which do not depend upon the button cell battery in the key fob.
Old Oct 27, 2019 | 02:17 PM
garvan62's Avatar
2000 S430
The battery good, starter relay good, jumped starter at relay cranks over, but no start, 60,150,200 amp fuses are good under carpet, tested all the fuses under hood all good but one f11 front cig lighter keeps blowing, don't think has any thing to do with starting. The key fobs two of them plus the emergency key doesn't work. What should I check next? Thank You
Old Oct 28, 2019 | 07:50 AM
wallyp's Avatar
Perhaps neutral start switch circuit. Be aware that the shifter unit is a "theft relevant system" that cannot be replaced alone.
