S500 Big Brakes?
https://pbbrakes.com/
if you want to get used W221 bigger brake s63 parts from a 2007-2013 s63 they will work also , see here
https://mbworld.org/forums/cl-class-...e-upgrade.html
Of course, most of the time the desire for bigger brakes is stylin' rather than function, and that may well be the case here.
The S55 and CL55 Kompressor have 360mm front discs and 8 piston callipers that will bolt on. Discs and pads are cheap, but callipers expensive.
The S65 and CL65 have even bigger 390mm discs that will fit. Discs are expensive. Same callipers as S55, different mounting brackets. The rear brakes won't fit - the rear offset is much greater.
SL55 and E55 brakes won't fit - different disc height. .
Nick
