Motor temperature high (maybe?)
Old Jan 17, 2020 | 07:34 AM
Oliveri's Avatar
W220 S500 2002
So I have quite unstable temperatures on my car, or at least I think so, I’m asking if it’s normal or not
well to start with, the car is a 2002 S500
So the temperatures that I keep seeing is anywhere from 80-95ish as far as I can see it’s not going over 100 but it gets very close and as I said it’s up and down as it don’t look like there is a stable temperature
Also the cars engine tends to take up to 15min to hit the 80 degrees mark which to me seems like a long time, outside temps are usually over 8 degrees (all is in Celsius)
also unrelated to that the fans in front only blows cold air while the one in the back blows hot air, cold works on both like normal but front won’t get warm (4channel air conditioning)
Old Jan 17, 2020 | 10:02 AM
wallyp's Avatar
2003 S500 2007 GL450
There is nothing magic about a temperature of 100C in your engine. The boiling point in your cooling system (assuming 50/50 mix of the proper coolant and water, and a proper pressure cap) should be somewhere between 120C-125C. The designed/desired operating temperature is usually considered to be 90C-95C.
The coolant temp is controlled by a thermostat that blocks flow to the radiator when the coolant temp at the thermostat is lower than the designed temp for that thermostat - which may vary. Coolant should be flowing to the heater matrices all the time. In the W220, coolant flow to the heater matrices is largely controlled by the duo valve, or in your case, duo valves (one front, one rear).
Coolant temp is affected by ambient temps. At 8C, radiation from the engine is significant, so the coolant tends to be cooler.
Thermostat operation is initially a batch process. Everything is at 8C ambient. When the warmer coolant from the cylinder heads hits the thermostat, it begins opening, and typically opens more than is ideally desired, thus slightly over-cooling the engine. This closes the thermostat a little more than is ideally desired, increasing coolant temp. This cycle slowly damps out, so that the coolant temp will eventually almost stabilize. Some initial fluctuations are normal, and not serious.
The cold air from the front heater matrices is very probably due to a failing duo valve. Cleaning and lubricating the duo valve pump motor and solenoid valves will often restore function. It is somewhat of a gamble, with the trade-off being your time and effort to remove the duo valve being the same whether you try to refurbish it, or whether you install a new one. You are balancing the cost of a new duo valve against the probability of the refurbishment being successful.
https://w220.ee/Duo_Valve
https://mbworld.org/forums/e-class-w...rol-valve.html
Old Jan 17, 2020 | 10:55 AM
tusabes's Avatar
Mercedes
These cars are fitted with a 95 degree thermostat and temps from 80-95 on the gauge are normal
Old Jan 17, 2020 | 12:36 PM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
A slow temperature rise is obviously a defective Thermostat. Relatively cheap and simple to swap. And then see what happens.
Old Jan 17, 2020 | 01:54 PM
cowboyt's Avatar
Mercedes-Benz S430, S500, S600, and E320 CDI
In town driving with a lot of stop and go, I often see 90 to 95 deg C. temperatures. When I'm cruising on the highway, the temperature drops to 80 deg C. or just above. When I'm doing combined driving, then if I end up doing 40 mph for a little stretch, the temperature will come down from 95 C to about 85, and ultimately 80.
All of this is very normal for W220's, from the S350 all the way to the S65 AMG. Our S600 TT behaves exactly like our S430's and the S500 in this regard.
Have you been able to get an idea if your higher temps are happening when you're doing a specific type of driving? Same for your lower temps?
Old Jan 17, 2020 | 05:23 PM
Oliveri's Avatar
W220 S500 2002
I would say I have noticed something simmelar, driving from red lights over and over tends to heat it up quite a lot (about 95) standing still after it’s that warm will usually bring it down to around 85-90
driving on the highway it’s usually around 80-85
Old Jan 18, 2020 | 11:31 AM
cowboyt's Avatar
Then you're just fine. That's absolutely normal. As long as you're not going above about 95 C, or below about 80 C after full warm-up, you're good.
Old Jan 18, 2020 | 12:38 PM
tusabes's Avatar
Mercedes
Yeah you’re fine .
Most people get concerned. Because Mercedes uses an actual gauge that fluctuates broadly , while others carmakers “gauges” are really programmed to stay stuck in the middle position at all operating temps and they only move to hot when overheating .
The Mercedes gauge actually normally heads between 1/2 to about 3/4 hot during normal operation.
Old Feb 13, 2022 | 03:23 AM
theokgs's Avatar
mercedes c230 kompressor(1.8 192ps) sportscoupe
yes i i have exactly thesame problem as you....my w203 c230 the temperature fluctuating all the time as you between 80-96 C°.i think this thing is not normal because i tested that after 90C° the radiator fan is on and close to 96C° runs on high like a turbine and after 30 seconds the temperature goes to 80° and the radiator fan is off again...this thing is happening all the time.to mention that the AC is off and the temperature outside is winter about 5° C.do you have the same problem?and also the fan opens and to your car or only temperature is going up and down?
Old Jul 20, 2023 | 06:47 PM
Futility2006's Avatar
2001 S500
Coolant temp
my 01 S500 has this issue however she. The temp gauge gets close to 100 I get serious lifter ticking, replaced all the lifters and the car still seems to do this. I have changed everything including the thermostat water pump radiator dual valve. How is this? I had the cooling system flushed and the car still does this. Maddening.
Originally Posted by tusabes
Yeah you’re fine .
Old Jul 21, 2023 | 10:37 AM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
lots of parts changed for what?
What kind of oil?
Status of car:milage?
Old Jul 24, 2023 | 12:51 PM
tusabes's Avatar
Mercedes
did you read what everyone said above ? Your coolant temp getting close to 100 is completely normal . The lifters tick is not normal
Old Dec 21, 2024 | 12:38 PM
Sourwaves's Avatar
Temp gauge
question, my temp gauge has been dropping slightly below 80 maybe by 5 degrees when driving on the highway. It’s a bit cold here in nyc about 32 degrees
Old Dec 21, 2024 | 02:22 PM
tusabes's Avatar
Mercedes
Perfectly fine don’t worry
while 80-95 is typical ,note that in cold or hot conditions it’s not abnormal to see 75-100, still nothing you need to do
if you were below 70 or above 105 then it’s time to look for a problem
Old Dec 21, 2024 | 03:00 PM
Fried Chicken's Avatar
2005 S500 Designo
I just had this happen... and then it idled weirdly high.
This was after doing some heater core tests (the heater needs to get hotter, something is wrong... maybe the duovalve motor, maybe it's wired incorrectly, I do not know. Been an issue since I got the car. Maybe the heater core is clogged but no evidence to suggest that)
Old Dec 21, 2024 | 03:12 PM
Sourwaves's Avatar
gotcha thank you, also a bit unrelated. I just replaced my blower motor . But the heat doesn’t seem to blow as good as The original blower motor, let alone the heat being hot. It’s luke warm with heat on hi and it blows like it’s set on low when the fan is on high . Problem with the new blower motor ? Or just a cheap blower motor . Originally the oem blower motor and the resistor which I believe was the behr resistor **** the bed and no air came out at all. So I had to replace with aftermarket. The middle vent blows almost like it has ac on and then it turns hot when it wants to or the car gets above 80+ Celsius side vents in the front blow luke warm and barley push out air at times ,the rear seems to be fine with hot air consistently and air flow .So confused also thank you for the quick response
Old Dec 21, 2024 | 03:32 PM
tusabes's Avatar
Mercedes
Chinese part?
Better to get used original blower in eBay than a Chinese blower motor
Old Dec 21, 2024 | 09:14 PM
Sourwaves's Avatar
Yes I believe Chinese part
I’ll look around , my oem blower motor was shot but worked better then this new one
Old Dec 22, 2024 | 03:22 AM
2005 S500 Designo
Chinese part?
How can a chinese blower motor cause low heat?
Old Dec 22, 2024 | 12:34 PM
wallyp's Avatar
" But the heat doesn’t seem to blow as good as The original blower motor,..."
"... it blows like it’s set on low when the fan is on high ."
Like that.
Old Dec 23, 2024 | 12:12 PM
2005 S500 Designo
Like that.
I've not noticed that, air is plentiful
Old Dec 23, 2024 | 07:56 PM
Sourwaves's Avatar
Last silly question for a bit
When the heat is on it seems to be quite hotter when the temp gauges are above 80 in stop and go traffic once it gets to 80 or slightly below the center vents turn somewhat cool . Now I know I’ve seen threads where they’re saying the center vents on mb are meant to blow cool rather than hot . Is this true (2004 s500 4matic )
Old Dec 23, 2024 | 08:48 PM
Sourwaves's Avatar
This is how low the temp gets when consistently driving , was going about 80mph .
Old Dec 24, 2024 | 12:24 AM
Sourwaves's Avatar
[img alt="Codes !!
Last but not least I ran into a few codes the p200a seemingly to be the most of my concerns . No lights on the dash but the car does seem to have a slight rough idle when just sitting any ideas ? Says it’s indicating an issue with intake manifold runner control (IMRC) system on bank 1 of your vehicle's engine"]https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/920x2000/img_9558_7d3c68e3d166c47c1147aaeb1e6e29b26878b7a3. png[/img]
Codes !! Last but not least I ran into a few codes the p200a seemingly to be the most of my concerns . No lights on the dash but the car does seem to have a slight rough idle when just sitting any ideas ? Says it’s indicating an issue with intake manifold runner control (IMRC) system on bank 1 of your vehicle's engine
Old Dec 31, 2024 | 06:53 PM
Sourwaves's Avatar
Originally Posted by Plutoe
post 22----answer yes
post 24----wtf
what does that mean for post 24 (the code p200a)
