Reset of service indicator challenge
Old Jan 23, 2020 | 02:50 PM
DK14's Avatar
W220, 320, CDI, 2003
Solved - Reset of service indicator challenge
Dear all,
W220, 320CDI, 2003.
For fun reasons I tried to resetting the service indicator with ICarSoft tester. After this it’s only saids service has to be done, and it’s not possible to reset at normal procedure with the R button. I can only switch between a and b service and it saids service has to be done and The oil status does not work.
Anybody have a clue with this challenge?
Thank you very much.
Old Jan 24, 2020 | 01:44 PM
Joseph~'s Avatar
2008 R320 CDI 4MATIC
Originally Posted by DK14
Dear all,
W220, 320CDI, 2003.
Review attached PDF copy instruction from WIS, this is for a w251 2007
Regards
Joseph~
File Type: pdf
Old Jan 24, 2020 | 02:31 PM
DK14's Avatar
Regards
Joseph~
Dear Joseph,
This Will not help my W220 I can see.
But thank you.
Old Jan 24, 2020 | 03:06 PM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
S-Klasse (W220)
  • Zündung einschalten.
  • Taster Systemauswahl wiederholt drücken, bis in der Multifunktionsanzeige der Kilometerstand angezeigt wird.
  • Taster Vor- oder Zurückblättern wiederholt drücken, bis in der Multifunktionsanzeige das Servicesymbol angezeigt wird.
  • Resetknopf für 3 Sekunden drücken. In der Multifunktionsanzeige erscheint die Abfrage "WOLLEN SIE DAS SERVICEINTERVALL ZURÜCKSETZEN? BESTÄTIGUNG MIT R-TASTE".
  • Resetknopf drücken.
  • Zündung ausschalten.
Hope your German ist good enough.
Old Feb 9, 2020 | 11:28 AM
DK14's Avatar
Dear all,
This seems to be a challenge for me.
Every time I start the car it comes up with the service indicator.
Like I write in the start topic it’s not possible to reset the service indicator anymore with the R button.
Please see attached photos. Do anybody know how to total reset the instrument display? Maybe this will work.
(I have tried with normally reset in display, but this do not work.
Old Feb 9, 2020 | 12:10 PM
May be there is an issue with the instrument cluster, as I see, you are missing the time?? It does not show, WHY??
Old Feb 9, 2020 | 12:46 PM
DK14's Avatar
That could be. When I put the new android system in the clock was away.
But the problem with the service indicator did first start after I tried to reset the service indicator with ICarSoft.
Old Feb 10, 2020 | 04:40 AM
Got it, if you replaced the Comand by Android, you need to have someone with Stardiagnosis to change the source for the time from Comand to "Radio". The reset of the service interval, I have no clue, sorry.
Old Feb 10, 2020 | 05:06 AM
DK14's Avatar
Thank you for the hint with the clock.
Old Feb 19, 2020 | 04:05 AM
DK14's Avatar
Challenge is solved.
I found a very clever technical person that could program the instrument cluster with the Star tester. The ICarSoft tester had totally damage the software in the instrument cluster.
