19's ......HELP
Old Aug 6, 2004 | 11:39 PM
MBAMG's Avatar
19's ......HELP
Help, please...I have posted this problem on another forum, the guys were very nice and helpful, but no solution was found...I have a set of Carlsson 19's on my S500, the car vibrates when it is running between 110 and 125 km/h...does anybody has a similar problem. The wheels are balanced already. My dealer told me that some of the S class with AMG package (18's) also experience the same problem, and they have no idea what went wrong...
Old Aug 7, 2004 | 12:12 AM
SL BRABUS's Avatar
2 SL with every Brabus mods available & Class A competition sound system
You might have bad tires. If the tires is good then the rims is no good. Time to get new rims. Go with Brabus and you won't have any problem . Good luck!
Old Aug 7, 2004 | 03:17 AM
MBAMG's Avatar
Thanx for your help SL Brabus! Would bad rims cause this vibration only on specific speed? Because if I am not in the 110 to 125 km/h range, the car runs fine (both below and above this speed range).
Old Aug 7, 2004 | 03:29 AM
SL BRABUS's Avatar
I Hope You Did Not Buy Use Rims, Because Use Rims Alway Have Problem. Carlsson Make Good Rims. Unless TheY Bend And Been Fix Then It No Good. AMG package should not do that because the car have to go over 130mph with out vibrates.
Old Aug 7, 2004 | 11:34 AM
Wolfman's Avatar
Super Moderator
I have brand new 18" AMG wheels (with Bridgestone Potenza RE050's) on our S500 and also experience some vibration between 60-70mph from time to time. Only seems to come from the driver-side front.
Somewhat puzzling asit's not consistent. Wonder is this could be an Airmatic issue.
Either way, make sure not to use the tire pressure listed in the fuelcap door as they are only for the 16" or 17" stock tires.
Wolfman
Old Aug 7, 2004 | 05:39 PM
MBAMG's Avatar
Thanx Wolfman, your post really made me feel better ....I was quite upset when the dealer told me there might be nothing they can do...I will keep you informed if they found out what the problem is. Thanks again!!
Old Aug 7, 2004 | 06:43 PM
Thericker's Avatar
V12-Biturbo
I have also expierenced moderate vibration from 60-75mph
Somewhat puzzling
Wolfman
Interstingly though I'm positive it's the tires I recently replaced my old tires(Michelin pilots) with Toyo's same size swap 245/18/40 all around.
I had this local tire shop pulling their hair out !! I brought it back 5 times and they couldn't fix it, then they started arguing that it must of been an existing problem before the swap. So I suggested puting my old tires back on and then have the shop manager test drive it w/me and sure enough no vibration!!Go figure. But since I allready drove on the new set they wouldn't give me my money back but instead offered a deal to far in their favor for some new Michelin pilots..Hence I'm just abusing these Toyo's until they fall apart they're cheap!! :v
Old Aug 7, 2004 | 06:49 PM
Thericker's Avatar
V12-Biturbo
SLBrabus how old are you? Your writing skills, make you sound like a Cave Man ugh...
Old Aug 7, 2004 | 10:10 PM
SL BRABUS's Avatar
I maybe sound like a cave man but at least I drive a REAL BRABUS car ……Don’t be jealous cause you can’t afford a Brabus car . Oh by the way please don’t put a cheap imitation rims on your S500 . Oh yeah I forgot you can’t afford nice rims .
Old Aug 7, 2004 | 11:19 PM
MBAMG's Avatar
I've never thought of that, thericker55, thanx I'll certainly have somebody check on the tires for me. I think the tire shop which put on the tires on the rims for me was taking advantage of me. They used truck valve stems (which are like 5cm long) instead of my original ones (I found out about this when I went to a tuner shop and they were laughing at my extremely long valve stems). Thank you so much guys
Old Aug 15, 2004 | 11:44 AM
esntrk1's Avatar
2000 S500
The Michelin Pilot Sport A/S is definately the way to go. Hands down, nothing better.
Old Oct 14, 2004 | 03:59 PM
Kochos77's Avatar
My buddy had the same problem with his 18 inch Brabus wheels. The problem ended up being that he needed centering rings that go on between the wheel and the hub.
Old Oct 14, 2004 | 04:43 PM
XenoS500's Avatar
Thumbs up nice try
Your buddy sounds like a coool dude.
Old Oct 14, 2004 | 06:59 PM
wildting's Avatar
I'm running 20's an have had no problem with vibration... it may be your tires.
Old Oct 14, 2004 | 07:31 PM
ArMaNi S500's Avatar
2000 Mercedes S500
Talking
eez maybe SL BRABUS a terrorrists of al quaida and no know english speaking but is funded with money from da osama? mister caveman man. u no have a Brabus SL is cuz you talks too ineducated for to be able to a ford won......
Old Oct 17, 2004 | 12:36 AM
dmike67's Avatar
2000 S500
That was funny ArMaNi... Thanks for the laugh ! ! !
Old Oct 17, 2004 | 02:56 AM
2000 Mercedes S500
hehe i do what i can..
Old Oct 21, 2004 | 05:36 PM
sportlichE430's Avatar
Arrow
SL BRABUS (aka Johnny Damon)
Congrats on being the BoSox MVP game 7 in the Bronx
You like play caveball world series in Uston arggh Sant Luis?
Old Oct 21, 2004 | 08:23 PM
SL BRABUS's Avatar
Hahahaha.. .....You a very funny man........You hurt my feeling by calling me terrorrist. ....why you have to be so mean... ....If you think you could speak better english then me then you could teach me Mr. Armani (The English Teacher Terrorrists) some of your wack terrorrist language
Cheers
