Thump consistent with wheel rotation
initially, but after the first pump comes up and feels more normal. The inner pad on both wheels was shot, and the outer pads about 1/2 way. Don’t see how I could have gotten air into the system, but I assume the brakes need to be bled (I planned to use the 2-man pump method). Then, the next day, I took the car for a ride to see how the brakes were responding. After awhile there was a thumping noise that seemed to be coming from the front driver-side wheel. Frequency varies with the rotation speed, and I can feel it through the floor board. It disappears when I depress the brake pedal. Popped off the wheel and everything looks fine. Comments/suggestions welcome before the car goes to the mechanic.
With engine not running, pump the brake pedal slowly several times. This should exhaust the reserved vacuum in the brake booster. Let the pedal sit in the fully-released position for a couple of minutes. Push the pedal firmly once, and hold it. Any softness indicates either air in the system or a soft brake hose. The pedal should be hard and near the top. Press and hold the pedal with moderate pressure while starting the engine - the pedal should drop and get softer, which shows that the brake booster is working.
The pistons in disk brake calipers should not move back and forth. When you apply the brakes, the piston should move only enough to distort the rubber seals so that the pads press against the rotor. When you release the brakes, the rubber should straight out which releases the pad pressure against the rotor - but the pads should still lightly touch the rotor. When the pads wear slightly, the rubber seals will distort as much as they can, and if that isn't enough, the pistons will slide out a tiny, tiny amount until the pads press against the rotor.
If the rotor is warped, it will knock the pistons in as it turns. The next time that you apply the brakes, the pistons will have to slide back out so the pads press on the rotor, causing a long and soft pedal. The brake pedal may or may not pulse while you are stopping.
If there is a "hard spot" in the rotor (usually caused by parking the car with very hot rotors) the rest of the rotor will slowly wear more than the hard spot. The difference in rotor thickness will gradually cause more and more pulsation in the brake pedal, and will eventually make a noticeable pulsation in the deceleration of the car.
If your calipers have pistons on both sides of the rotor, uneven pad wear usually indicates a sticking piston or pistons.
Replacing rotors is not a difficult job.
While you have the rotor off, spin the hub to make certain that rotation is smooth and quiet, and that there is no free-play in the bearings.
Make certain that there is no foreign material in the rotor , and that the rotor is seated correctly on the hub, with no foreign material between.
First - many thanks for the comments/suggestions on my post. I don’t think it’s a bearing issue. I’ve had a bad bearing on other cars, and it typically is more like a grinding noise. Besides, when I put on the spare to confirm it’s not a tire issue, I spun the wheel when it moved freely with no noise. I know it’s not under load, but I’m pretty sure I’d hear something if it was a bearing. I thought the idea of swapping the rotors was a good one, though it will have to wait until the weekend when I have more time.
But...
I went out tonight to stretch the legs of one of my corvettes, and noticed the 600 sitting down in the back, practically on the rear wheels. I’m no stranger to ABS issues, and sure enough, started the car and got the dreaded orange “ABC Failure - Visit Workshop”. About a month ago I had the motor mounts replaced and one of the ABC lines that was crushed when the mount(s) failed. I’m concerned that this is going to get expensive really fast.
Does anyone see a connection between the “thumping” I heard with the ABC warning I’m now getting? I don’t see how they are connected, as I’m pretty certain that the frequency of the thumping varied with the tire rotation speed. Thanks in advance for any/all comments.
when I out the spare on to see if it was a tire issue, I checked the ABC fluid level. It was just at the low level, so I did top it off. Not related to the wheel sound - but could overfilling throw the ABC warning light?
when I out the spare on to see if it was a tire issue, I checked the ABC fluid level. It was just at a low level, so I did top it off. Not related to the wheel sound - but could overfilling throw the ABC warning light?
As for your brakes, I would take the rotor and caliper off on the suspect side and see if you find something wrong. You may have missed something the first time. Also, go ahead and bleed the system if you still haven't. Check the rubber seals around the pistons too. Good luck!
re the wheel thump - the more I think about this the more I think it has to be a tire. Although I was convinced it was the front driver side - I’m going to start swapping out the other wheels 1x1 with the spare to see if it goes away. Then swap the rotors. If no luck with either of these, it’s going to the mechanic. I’m also working on the stuck shifter issue but will post that separately.
I love this car, but sometimes...
Thanks again.
