after market head unit
https://www.benzworld.org/threads/an...#post-18163512
The pins on the main connector for the radio appear to be:
pin 4 battery red/yellow stripe (always live)
pin 8 earth brown
pin 5 switched power out to antenna amp. blue This needs to remained hooked to the antenna amp and be powered when the radio is ON. There is usually a blue wire out of most radios for this. If the antenna amp isn't powered, performance will be very poor.
pin 2 OBD-II pin 3 yellow/white
pin 3 mute for telephone use
There is a "C" connector shown. pin 1 is CAN-BL, pin 2 is CAN-BH. PIN 4 is WAKE UP blue/black This goes to CD Changer - if no changer, line is tied back (dead-ended).
There is a "B" connector shown for radios without a sound system. The eight pins here are for the speakers.
My first try would be to find the connector located just behind the pull-out ash tray. This has the switched power for the cigarette lighter, the power to the light in the ash tray, and the earth. Earth is brown. Switched power should be either black/grey stripe, or grey/black stripe.
I hope that some of this is helpful...
Have you considered buying a copy of WIS (Workshop Information System) online? A good version will have wiring diagrams.
