S500 w220 Airmatic problem
Old Mar 30, 2021 | 04:58 PM
Cornea Ionut's Avatar
W220 s500
Hello guys, i changed the position sensor, the 2 back suspension, valve blocs, i test้s the compresor and the pump, they are good but my car still doesn't want to get up... The rear is on the rims and the front ๎s max up... What should i do ?...
Old Mar 30, 2021 | 09:20 PM
wallyp's Avatar
2003 S500 2007 GL450
My only guess is a faulty or poorly-installed rear height sensor.
Old Mar 30, 2021 | 09:37 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Why was all that replaced in the first place? Are you sure everything is hooked up correctly? I'd probably focus on the front, as a control... if the ride height sensor is manipulated, can you get front to lower and raise. If the front responds normally, then it would point to an issue with the rear sensor. Assuming your not hearing the compressor running and the rear is not raising.
Now if the front doesn't respond at all or correctly... then its a matter of figuring out if its a input and/or output issue.
Old Mar 30, 2021 | 10:30 PM
W220 s500
This one must move or should be fixed? Cuz i have put mine and i can't move that little thing
Like once i have installed it on the car, i can't move it left or right
Old Mar 31, 2021 | 10:38 AM
wallyp's Avatar
Some photos that might help.
https://www.benzworld.org/threads/re...oblem.2919194/
https://www.benzworld.org/threads/re...-dash.2934786/
