Hydraulic line interchangeability?
Old May 24, 2021 | 07:27 PM
shsh0709's Avatar
2001 BMW M5 2004 S55
Hello all
I took my car(04 S55) to a mechanic today to investigate a hydraulic fluid leak. He told me that the hose between the pump and socalled pulsation damper is the culprit. However, when I looked up the part number 2203204572, it seems that this item has gone out of production. Here are my questions: can I buy 2203204372, which was used on 01-03 car, instead? What are the differences between these two parts besides that one comes with the damper? Thank you.
Old May 25, 2021 | 10:22 AM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
It's not out of production, it's been superseded. Use the new part, it's got a better protective jacket on it.
Old May 25, 2021 | 12:19 PM
shsh0709's Avatar
Thanks. Do you happen to know the part number for the new one?
Old May 25, 2021 | 05:44 PM
Astro14's Avatar
Veteran: Navy
If we're talkin about the u shaped hose that acts as a pulse damper (the hose to nowhere), it's
2203205972
Old May 26, 2021 | 09:06 PM
Krazyleg's Avatar
C215 CL 600, W220 S65, W221 S550, 1969 442 vert, 2000 MCY Viggen vert, 1992 900 vert, 1986 B350 RR
Someone known on many of these forums, no longer with us, Bruce M, told me using hydraulic lines for the trucking industry is more cost effective and has higher psi ratings.
Old May 26, 2021 | 09:09 PM
tusabes's Avatar
Mercedes
that’s assuming you can remove the hose yourself or have a mechanic willing to take off the used hose and wait while you have a hydraulic shop rebuild the old line using new hose on the original fittings . Most mechanics either can’t wait or won’t work with old parts and require a new part ready to swap in while the car is on their lift
