Cranks only when battery first installed but won’t start.
intake noise, etc) instantly stops. Lights go out, (and nothing from the starter), I knew I f*#ked up. I pulled up the carpet on the passenger side and I had blown a prefuse. I had an extra hole in the prefuse box, which I assume would be used up by a different model Benz, so I pulled the wire and stuck it in the other hole. I had power again. Still in the same boat w/ the starting though. Since jumping the relay didn’t work I figured I had a stuck or shorted starter, so I went ahead and replaced it. When I went to start it, same issue. So I figured maybe the battery had run down being parked out there for a few weeks. I hooked up the battery to the charger and it said faulty battery again. I took that one back. They gave me trouble about returning it and said they wanted to charge it over night. Next day I came in and it still tested bad 8v if I remember correctly. The guy working this day grabbed me a new one and said he wasn’t supposed to but he checked the brand new one off the shelf and it was also bad. 3 batteries later they found a good one and I was on my way. Hooked it up and nothing. I went and jumped the starter relay again and could get the starter to turn over but not start. I decided to order a new prefuse and install it in case my rerouting job was somehow to blame for my issues. I installed that, topped off the battery 12.7v, 100%charge, hooked the battery back up. Turned the key and it cranked for maybe 3 seconds but didn’t start. I tried a second time and nothing, no sound what so ever. I tried 8 or 9 more times and got like a 1 tooth movement on the starter once, the rest was all just nothing at all. I unhook the negative from the battery, hook it back up and it cranks for 3 seconds, then becomes inoperable again. I can repeat this over and over. It will crank once after it’s reset, but then seems like it’s getting a signal to not allow a starting sequence. I can put the key into the 2nd position and jump the relay and get it running with starting fluid but it doesn’t take over on it’s own. All fuses checked…what am I missing? It gets the handshake from the key, brake switch must work as I can move it through gears and get it to turn over at least once when battery is first hooked up. Hear selector also obviously works. After it stops cranking I can hear something activating from behind me, I assume the fuel pump, like 2 second bursts, maybe 4 or 5 times, then again my trunk is open, could be an antenna, not sure but something to note (this car has so many things actuating in start up, it’s like a space shuttle). I’m out of ideas. Help. Oh and the dealership is 4 hours away, and I prob know more than most of them, and don’t want to pay for them to poke around at this hourly.
Perhaps "BenzNinga" can help you out.
I once had an '82' Lincoln Town Car that would every 3rd Blue Moon would run the battery down over-nite. Many attempts by Dealer to duplicate and fix. While one day checking something else, touched electric choke---it was HOT--should have been dead--- WTF, over. Turned out to be one segment of the alternator rotor was shorted to ground and allowing the choke heater to back feed to the ground when the alternator would stop on the particular segment.
The same vehicle had an ECU that would 'freeze up' some rare times and shut off the fuel pump on start-up---a 'no start' condition. Numerous Dealer tows and parts replacements to no avail. Problem persisted for years. One day when down in Caracas, Venezuela while retrieving my local car from parking at the Theater, helped another man trying to start his Lincoln---with same problem--- no fuel on crank. When I diagnosed the no-fuel condition, he immediately connected the battery backward for a second. The car then started immediately. He related the ECU programing defect was well known there!!!!
I have seen that "fix" work several times - but what was happening was that the momentary polarity reversal was kicking the stuck fuel pump backwards, allowing it to operate normally when proper polarity was established. I would never, ever do a polarity reversal on a modern vehicle with dozens of computerized control modules and computers!!
Note there is a second pre-fuse back in the trunk by the battery I would get both of them and swap both of them out.
Charge the battery make sure it’s fully charged. Then try starting the car. If that doesn’t work you’re gonna need the four antitheft parts which consist of key ECU, EIS, and shifter, all taken from the same donor car as they are coded to work together.
after rechecking every fuse, pulling my rear carpet (there was water back there must have come in the front and ran down the plastic channel the wiring runs in, dried it up, removed my rear Sam checked for corrosion, replaced my starter relay and the one next to it (motronic I believe), pulled both my sams out of the front and checked for corrosion cleaned and reassembled, again the starter is new, the battery is new, the large prefuses under the carpet are new… my scan came up good for eis, shifter and trans good, all other systems good (just so no one throws a “check your fuses under the carpet”,
my error is “start enable of DAS not sent”…
now from all the reading I’ve done there is no disabler on these cars just a series of “handshakes” of hash keys between the ecm, the shifter, and the ignition. I tried undoing the battery and holding the positive and negative cables together to try to discharge the capacitors (works on some cars). Hooked it back up and the car turned over for about 2 seconds and then back to doing nothing.
I checked the ECU codes for drive authorization and it says
“engine control module identified - yes”
”engine control module interlocked - yes”
“DAS and engine control compatible - no”
so my ignition recognizes my key, keeps continuous power to it, I am able to turn the key in all positions, my dash works, my accessories work, radio, steering wheel, all my gears show up on the dash, I can shift through gears freely, and on occasion (when I unhook my battery) I can get it to turn over a few teeth on the starter (only the first time). What isn’t communicating? It ran great for years, all I did was have a battery die. When I replaced it I had this happen.
I would get the ignition cloned to my car but the key obviously works, the scan tool says the ecm is good, it all worked before?
my spare key is the only key that opens my trunk, so it’s possible that these units have already been replaced, but they would have to have been replaced as a set. Is it possible that only part of the system (the ignition and other key) was replaced and cloned to the ecm? When they clone do they clone to the VIN number? If I get my ignition cloned to my VIN is it possible that my ecm won’t match my VIN? How do I check which if any of these parts are original if they don’t have VINs on them?
also is anyone seeing something I’m not? Thank you if you read this whole thing.
I realize this is really old, but did you ever resolve this?
