Lol what in tarnation is this squeaking noise? (video)
Old Apr 29, 2022 | 12:43 AM
DimcheSRQ's Avatar
2001 S430 W220
So this noise just came out of nowhere on my 2001 S430, 108k miles, any clues? Turning hvac on/off made no difference. I cannot correlate it to brake usage as I was coasting. It is most exaggerated when coasting, somewhat less when accelerating but still hear it during acceleration. The particular speed of the vehicle doesn't matter either.
Old Apr 29, 2022 | 12:47 AM
DimcheSRQ's Avatar
2001 S430 W220
Also I'd like to add it's pretty loud in the cabin, almost as if it's coming from the dash area and not outside.
Old Apr 29, 2022 | 01:22 AM
tusabes's Avatar
Mercedes
Do you have the Ac on? If so the most likely culprit is the blower motor, it’s very easy to replace with a used blower motor from eBay it can be done from the engine compartment the dash does not need to be taken apart. Other possibilities are a loose door card , which is the inner door panel squeaking against the door frame or door sill, or a loose exhaust
Old Apr 29, 2022 | 09:33 AM
DimcheSRQ's Avatar
2001 S430 W220
I tried with the ac on and off it did not make a difference.
Old May 1, 2022 | 09:02 AM
chassis's Avatar
2017 GLE350 4MATIC
Where is it coming from? Front tires? Rear tires? Under your seat? What do you think it is?
Old May 4, 2022 | 08:08 AM
nokiagird's Avatar
S350
i see that you turned on the AC i think its from cabin blower
Old May 5, 2022 | 03:09 PM
DimcheSRQ's Avatar
2001 S430 W220
I really don't know. It seems like it's coming from inside the cabin. I had thought it was the blower but it was happening even if I hit the 0 to fully turn off the a/c.
Old May 8, 2022 | 11:00 AM
tim687's Avatar
CL 600 '00 5.8L V12
Could it be the sunscreens/sunshades at the top of the roof?
Something completely off-topic, is that a stock COMAND 2.5? Or do you have modded it?
Old May 9, 2022 | 10:41 AM
DimcheSRQ's Avatar
2001 S430 W220
No sir the noise isn't coming from the top as I hear it. Also, the COMAND system is stock and the screen is totally damaged from I guess the sun and time lol.
