Airmatic visit workshop after replacing Abs speed sensors on the front
Old Jun 9, 2023 | 09:44 AM
Mookie1987's Avatar
2015 Mercedes-Benz S550 4MATIC, 2021 GLC300 4MATIC Coupe and 2006 S500 RWD
I replaced both my speed sensors on the front the driver side was easy. I struggled with the passenger side. I unplugged the height sensor and the one going to the air cylinder to get better access. I fought with the abs wire until I realized it had a key on it 🤦🏽‍♂️ holding them in place. I finished the job plugged everything back up and now my Airmatic visit workshop error shows. The system still works though so I don’t understand what is going on. It was fine before then.
Old Jun 9, 2023 | 08:47 PM
wallyp's Avatar
2003 S500 2007 GL450
Is the error "STORED" or "CURRENT AND STORED"?
Old Jun 10, 2023 | 10:03 AM
Mookie1987's Avatar
It is current. I had unplugged the battery for 30 seconds to reset the ecu. The check engine light turned off but the bas abs esp and airmatic was still on. The check engine light came back on after a few cycles. The engine code is P0500-Speed Sensor A
Old Jun 11, 2023 | 10:06 AM
wallyp's Avatar
"One possibility is a poor connection at one or both of the harness connectors at the front wheelwell. The two little plugs at each of those connectors are notoriously difficult to insert properly. Make sure that the spring wire clip is attached correctly, hold the plugs tightly together and firmly insert."
Old Jun 12, 2023 | 04:08 PM
e350forme's Avatar
fleet
no idea about the airmatic or the abs speed sensors (I would use my scanner to look at those modules/systems individually, check values, tests, resets ect)
does the EPS go away when you turn the wheel lock to lock? happens to every benz when you disconnect battery
Old Jun 12, 2023 | 05:23 PM
Mookie1987's Avatar
Well took your advice and it was not plugged all the way lol the “Airmatic visit workshop” disappeared but my abs bas and esp still on and I tried the steering wheel reset again to no avail 😫
Old Jun 12, 2023 | 05:25 PM
Mookie1987's Avatar
The lights stay on no matter what I perform the wheel lock to lock numerous time
Old Jun 12, 2023 | 05:33 PM
e350forme's Avatar
fleet
others can chime in, I am not an expert more like a first responder
whenever I get ABS messages, it has to do with the reluctor rings on the axles, right?
do you have a scanner to see if each wheels axle abs sensor is picking up a signal?
I use my foxwell scanner to diagnosis and then tell mechanic what to fix lol
Old Jun 12, 2023 | 05:57 PM
Mookie1987's Avatar
no but i really need to invest in one lol this abs this is a nightmare from the depths of hell 😈. I never check the reluctor rings
Old Jun 13, 2023 | 01:34 AM
tim687's Avatar
CL 600 '00 5.8L V12
You really need to get the car scanned with SDS. Get an SDS system and it'll tell you whats wrong
Old Jun 13, 2023 | 09:11 AM
Mookie1987's Avatar
which one do you recommend?
Old Jun 13, 2023 | 10:51 AM
e350forme's Avatar
fleet
FOXWELL NT530
dont be like me an order a bmw software one thinking I was getting a nice deal, and then had to pay 79.99 for the mb download file to make my own sd card for the scanner. so buy the one already loaded with MB software/version
I dont know of any other readers because I dont have any, I guarantee you there are better ones for more money
Old Jun 13, 2023 | 10:54 AM
e350forme's Avatar
fleet
hes right
but for homemechanic diagnosis this is more of a side note we are talking about
Old Jun 13, 2023 | 03:54 PM
tim687's Avatar
CL 600 '00 5.8L V12
C3 or C4 multiplexer
Something like this:
https://www.ebay.com/itm/26577084093...3ABFBMtJiY5ZZi
Old Jun 21, 2023 | 01:20 AM
raez77's Avatar
w220 s320
Did you check leveling sensor?
