Driver seat not moving properly
I have 06 S430. I lost the movement control of the Driver seat lately. When pressing the back and forth button on the door it only moves the seat toward the front, it won't move toward the rear. The other buttons (up/down, incline) work fine. I notice the 1,2,3 Memory buttons only work in the same wrong fashion, meaning it only moves the seat forward, not backward for a preset memory. My seat is very close to the steering wheel now, I am afraid to press the button anymore. The passenger seat and memory buttons work normal. Please help, thanks in advance.
Besides those fuses checking, is there any Relay that I should check? or any water damage in driver side of the car I should check (I don't think so but just asking)?
Standard DC (Direct Current) motors will reverse directions when you swap the positive and negative power leads. That is how the seat motor moves the seat both forward and back. If the seat moves forward, the motor and the wiring to it must be okay. If you get the seat so far forward that you can't drive the car, you should be able to move it to the rear by finding the wires going to the motor, reversing them (even if you have to cut both wires to do so), and pushing the FORWARD button.
I could not move the seat any more by pressing any seat function buttons on the door. However, I still can press the 3 memory buttons but it only moves the steering wheel up/down at preset point earlier, no seat and head-rest movement at all. The seat has been moved forward to maximum position that is pressed near the steering wheel. I popped open the DCM (220-821-15-79) off the door and looked at it but could not pull out the 3 plugs that control the seat since if I force them out the plastic holder might break or the wires might be cut off, the DCM look pretty new. Does anyone have an idea how to pull them out? With the hung out DCM, the 3 memory buttons and the mirror buttons are working.
The passenger seat (right door) movement are all OK which mean the fuses are good. Only the driver seat movement does not function. I am run out of idea. Should I try to remove the seat and look for anything? I've never done that.
Thanks.
That means that the only possible point of failure is the switch contacts in the DCM. That means that the possible repairs are to open the DCM and repair the contacts, or else to replace the DCM.
It would seem a simple reset could fix this but I don’t know
Is there any specific fuse that control the driver's buttons, or any other helpful suggestions? For now I just need to move the seat a little bit backward so I can sit and drive comfortably, and I will not press any buttons after that.
Had that issue with my door. Just broken wire, but a pain to fix.
