Problem with light in door handle recess-help!
Old Dec 28, 2004 | 09:42 PM
ruykava's Avatar
Mercedes all the way!
hi everyone, i have a 2004 S350 in the far east. recently there's been an annoying problem with the little interior light in the door-handle recess. the one on the right rear keeps turning itself on and off repeatedly--it seems like some connection is loose. we don't have a real merc dealer here and the general mechanics can't find whats wrong. has anyone else got this problem? and how did you solve it? any help is very, very much appreciated. thanks!
Old Feb 7, 2007 | 09:33 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
My front passenger door recess light is off also. is there a bulb at the end of the fiber wire? anyone know how to get to it? thanks..
Old Feb 8, 2007 | 10:05 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
I dont think it's a fiber optic but a small SMD-LED, like the lighting in the foot wells. To get to it you need to take the upper part of the door panel off.
Pry off the wood carefully, open the 4-5 screws you find behind the wood, take out the little cover under the upper part of the door handle, another screw appears, then you pull off the plastic part including the seat memory thingy. Then you should have access to the recessed LED or what ever it is.
Old Jun 9, 2008 | 06:28 AM
richardliebert's Avatar
2005 S500 4MATIC
Warranty?
In your opinion, if the LED in the rear interior door handle burns out would that be considered a warranty item or normal bulb wear? My S500 is still under factory warranty. I would prefer if the dealer made the repair?
Old Jun 9, 2008 | 09:43 AM
my06clk's Avatar
I replaced mine.. it was 8.00 at the dealer. its not a light, but a small led module that is housed with a resisitor and a light pipe. it connects to the DCM.
I'm thinking it should be warranty if your car is covered, but mine wasn't. ITs a quick and easy fix.
Old Jun 9, 2008 | 02:54 PM
SUNILP's Avatar
2015 E250D
There is a surface mounted LED with resistor to drop voltage. The light passes through a fiber optic tube and lights the interior of the handle. This is what all the w220 from 2003-2006 got. Earlier cars has a different lught (i think was a bulb)
Old Sep 28, 2008 | 06:39 AM
2005 S500 4MATIC
Tips on removing the wood
Do you have any tips on removing the wood. I'm concerned that I'll crack it.
Old Sep 28, 2008 | 04:38 PM
Trey's Avatar
2008 S550 designo
My rear passenger light is out as well. I bought a new one at the dealer ($15)and attempted to remove the door panel. I managed to get most of it apart, but something at the top was holding it too tightly to get in there and do anything. I have yet to see a good write-up on door panel removal and I have door shades that just complicate things. I decided to stop before breaking things and will wait until I take it to the mechanic for service to have it replaced.
From the shape of the module, I believe the entire door panel needs to be rmoved to gain access. The main body of the module goes behind the door handle with the fiber part wrapping around the back of the handle to the front.
trey
Old Sep 30, 2008 | 02:12 AM
my06clk's Avatar
trey
YOu don;t have to remove the door panel to change this part. Only the wood trim and handle piece the module clip into the handle from the back but it can be removed as the tabs are facing you when you remove the handle cover. you just have to fish your hand around and grab it.
Old Sep 30, 2008 | 07:58 AM
Trey's Avatar
2008 S550 designo
There is no way you can get your hand behind mine. Not sure what the difference is, but it is not possible.
Old Sep 30, 2008 | 12:37 PM
my06clk's Avatar
I should clarify,, yes have to pull the door panel out slightly, but not remove it.
IF you remove the wood trim, then remove the handle insert, you can see the module clips, they may be covered with some clear glue looking material You just push those tabs back and it frees the module.. If i get time today I will take mine apart and send you pics of how to do it.. Its not as hard as it looks...
Its the same way you get to the DCM except that doesn't get removed.
I'll post a DIY Later today. Been away to Germany the past 10 days so I have to cut my grass so I can see my house from the street again..
Old Sep 30, 2008 | 04:12 PM
Trey's Avatar
2008 S550 designo
That would be great. Maybe I just missed something obvious.
Thanks,
Old Oct 18, 2009 | 04:50 PM
Quadcammer's Avatar
96 and 08 911 turbos
Can anyone shoot me a part number for one of these lights?
One of the lights took a dive on me, and the only part I found 220 820 04 21 (or 03 21 depending on side) are listed as being $30 retail price.
Old Oct 18, 2009 | 05:18 PM
Trey's Avatar
2008 S550 designo
Sorry, don'thave the part number, but I wouldn't doubt if $30 is the current price. Plug the part number into parts.com OEM part search and see what their price is.
Old Oct 18, 2009 | 05:24 PM
Quadcammer's Avatar
Yeah, parts.com has it for $17, which isn't hateful, but then again, its a tiny led.
No big deal, just wondering if I had the right part.
Old Oct 19, 2009 | 01:22 PM
my06clk's Avatar
I have the part number for the right side A 220 820 04 2 1 So you're numbers are correct.
YOu found them for 17 bucks at parts. com That's good I'm going t look there also.
You may want to get some door new clips for the slim door trim as they will likely be toast when you remove the trim. those trim peices can only be removed a couple of times befor the clips have to be replaced.
They are a little over 2bucks a peice at the dealer. I think there are 4 of them total per trim peice. Sorry I don't have the number I just tossed it the other day and forgot to record it.
Old Oct 19, 2009 | 01:25 PM
Quadcammer's Avatar
Yeah, I have the clips. I think its 2208204478 or something similar.
Old Apr 11, 2010 | 09:21 PM
dweb4's Avatar
S550 4-matic
My door handle LED on the drivers side just starting turning off and then on again every couple of minutes. From the earlier post on this topic is the LED about to go out and will replacing it solve the problem. Also any DIY threads with pic's on how to remove the upper door panel.
Old Apr 12, 2010 | 03:48 AM
AH1W-COBRA's Avatar
2003 S500, 03 C240, 03 E320, 03 tahoe
im not convinced it is the led
both our front doors do this intermittently.for the past two years,so it cant be the led.is the light on at all times that the ignition is on or is their a circuit/sensor that switches it on when it is dark?
Old Apr 12, 2010 | 09:01 AM
dweb4's Avatar
S550 4-matic
if i'm not mistaken the light comes on when the doors are locked and unlocked as well as when you have your lights on in the evening. i'm gonna try and take the upper panel off to get to the unit if anyone has any pic's of how to take the panel off would be appreciated.
Old Apr 13, 2010 | 08:49 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
You will have to remove the entire panel, and you should use a plastic or nylon panel removal tool to avoid pulling the anchors out of the panel and damaging it.
Unfortunately I do not have panel removal bookmarked to give you a link, but it has been written up either here or on BenzWorld - a search on "door panel removal" will probably get it for you.
Old Apr 13, 2010 | 11:02 AM
dweb4's Avatar
S550 4-matic
ok so the earlier post of having to remove the upper wood panel to get to the LED is incorrect or is it just easier to remove the whole door panel. i don't want to damage the door nor get involved with the removal and such with the SRS (airbag) on the door.
Old May 15, 2017 | 09:55 PM
Flatearther 77's Avatar
2000 s430 mercedes
my interior door handle lights will not turn off,in my 2000 s430 mercedes
Old Oct 8, 2021 | 04:43 AM
W210mae's Avatar
1999 E55
LED
Just found out the LED for the interior door recess lighting has been discontinued from the dealer.
Anyone know of any alternative solution?
Old Oct 8, 2021 | 10:39 AM
wallyp's Avatar
2003 S500 2007 GL450
I just searched for orange LEDs, then bought several, as they were very cheap. I took the light assembly out and replaced the LED. Just make sure that you have the polarity correct before you put it back in the door...
