Updated my 2007 command:Tons of new options!!
Old Nov 1, 2007 | 09:44 PM
  #51
steveb9771's Avatar
2007 CL550
I just had the update installed on my 2007 CL550
Issues:
1) As reported by others, the radio sound does not mute during nav system announcements.
2) My car does not have an option to select a route based on traffic, I can select fastest route or shortest route. No option for using RDS data for routing (i.e. Dynamic Route)
3) Backup camera lost the parallel park option as reported by several others
4) DVD video displayed while stopped and while moving slowly. One of the dealer technicians said he was researching a software patch to enable the display while under full motion.
5) Birds-eye display works
6) Shows which lanes to drive in (both on speedometer and on nav display) when approaching a transition from one freeway to another
7) Being in Southern Calif, it shows lots of traffic data.
8) Sirius channel change button on steering wheel now uses my channel list rather than the entire channel list. Telephone keypad allows selection of a saved channel. If you press the * key, then you can enter the 3 digit channel number instead of the position in your saved channel list.
9) Slewing the display has become quite slow. (i.e. if I am in full screen NAV mode and I attempt to slew with the control wheel/joystick).
Does anyone have an answer to the first 2 items?
I had specifically requested that the use the 0231 version of the DVD. I called last week and had them special order it. The dealer called me yesterday and said they they had just received it so I had the update done today. (Later I found out that NAVTEQ had mistakenly shipped the DVD for 2006 S,SL,CLS and CL vehicles).
Unfortunately I discovered that they had used the 0225 version. At first, one of their service managers said that the 0231 version was not compatible with 2007 models, only 2008. The first manager said that they could damage my system if they installed this version. I asked them to show me the package so I could see what model years it applied to. I challenged this and they checked their inventory and they did not have the 0231. After talking to other service managers there, they finally admitted that 0231 is probably the correct version. I got them to agree in writing to replace the DVD with the 0231 version at no charge once they receive it. The dealer paperwork said they performed the work specified by DTB P-B-82.85/592d.
It took almost 4 hours to perform the telematics upgrade. Several of the past ones this dealer had performed took about an hour. This might be because my car was one of the first CL550s (manufactured in Sept 2006) and may have required a more extensive firmware upgrade.
Old Nov 1, 2007 | 10:11 PM
  #52
konigstiger's Avatar
'71 Pinto
P-B-82.85/512d
Old Nov 2, 2007 | 01:43 PM
  #53
trumpet1's Avatar
2007 S600
The radio not muting while navigation announcements are being made is not just an S class problem. My wife's new C350 (Saks edition) has the same problem. However, in both of our cars I have adjusted the volume such that it really doesn't bother me anymore.
Old Nov 2, 2007 | 03:33 PM
  #54
Diesel Benz's Avatar
Could it be that MB changed this? Odd though if they would change it for one particular model where it used to be different. I think something similar was changed years ago, was it parktronic not any more muting the radio when they come up (cannot even remember if they do now).
Old Nov 2, 2007 | 05:44 PM
  #55
trumpet1's Avatar
2007 S600
As I sit here at my laptop and read this, it amazes me how I experience my parktronic sensor beeping everyday but can't answer that question either!! Normally I would get up and check it, but I'm a little too lazy right now
Old Nov 6, 2007 | 02:30 PM
  #56
i7iceguy's Avatar
2010 E350, 2007 S550 - SOLD, 2007 ML350
New Nav DVD just arrived at Laguna NIguel, CA. If anyone in that area, they are a couple in. My car is in the shop now doing the software update. At first the service advisor called and said there was no recall/update for my car then I referred him to the DTB # provided on this thread.
Will update later when I get my car.
Old Nov 7, 2007 | 12:15 AM
  #57
i7iceguy's Avatar
installed, everything is great except one thing. My dvd video does not seem to be working. The system thinks my car is in motion so it does not display picture and just shows the message, "Video is disabled while car is in motion" or something along those lines, however, the audio plays. I guess I need to bring the car back in to fix it
Old Nov 7, 2007 | 02:45 AM
  #58
Did you have the gear on Park?
Old Nov 7, 2007 | 07:40 AM
  #59
trumpet1's Avatar
2007 S600
In addition to placing the car in Park, you must also activate the EMERGENCY BRAKE.
Old Nov 7, 2007 | 11:28 AM
  #60
i7iceguy's Avatar
Thanks Trumpet. Did not even think about the Emergency brake because I remember someone saying you can watch video at slow speeds. Working great!
Old Nov 7, 2007 | 02:20 PM
  #61
The Euro car plays DVD/TV at slow speed.
Old Nov 12, 2007 | 12:26 AM
  #62
steveb9771's Avatar
2007 CL550
2008 USA Owners Manual shows new features
See http://www.mbusa.com/media/downloads...00_cl63amg.pdf
This is the manual for the 2008 CL and it shows ALL of the features provided by the upgrade. This should be identical for the S class since they have the same NAV system.
Old Nov 12, 2007 | 12:31 AM
  #63
steveb9771's Avatar
2007 CL550
The behavior of this appears to be a software configurable option set by the dealer when they installed the upgrade. I believe they can enable either no video, video with parking brake on only, or video at speeds less than 5 mph. My US car was recently upgraded and it displays video up to about 5 miles per hour and then blanks the video at faster speeds.
There was a posting earlier that pointed this out.
Old Nov 12, 2007 | 03:54 PM
  #64
trumpet1's Avatar
2007 S600
Very interesting. I'm sure what you're saying is correct. I bet my tech did it by accident and not by a recognized thought-out choice. I'm just going to leave it like it is as the only thing I'm putting in their at the moment are music DVDs (concerts like Earth, Wind, Fire, Chicago, Tower of Power, etc). I really don't care about movies that much. I eventually want to get up to the Chicago area and get the mod done at Mid city engineering where it will allow the front screen to show movies for the rest of the family to see. We don't travel enough to warrant putting them on each headrest (unless I get overruled).
Old Nov 14, 2007 | 12:20 AM
  #65
white07w211's Avatar
2007 e350 4matic
how are you guy you guys have been helpful i have a question though i have an 08 s550 sport 4matic. when i put the car in drive the video cuts off is there a way to keep it playing while in motion at any speed? thank you
Old Nov 14, 2007 | 01:02 AM
  #66
gbahri's Avatar
2003 CLK320
I have a 2003 clk and my radio doesn't mute when tghe nav comes on, it just lowers and it speaks over the radio. I like it better than muting it.
Old Nov 14, 2007 | 01:09 AM
  #67
trumpet1's Avatar
2007 S600
Now that I have the nav volume adjusted, I do too.
Old Nov 14, 2007 | 08:31 PM
  #68
steveb9771's Avatar
2007 CL550
There currently is no easy way yet. In theory it could be done with a software patch, but none have appeared yet. There are outfits that will modify your hardware to accomplish this at a cost exceeding $1000. I would prefer the software patch over cutting into the wiring in my car.
Old Nov 15, 2007 | 06:57 PM
  #69
Brian805's Avatar
07 S550 AMG Black Opal
Telematics/DVD Updated, No results
I could use a little help with this...
I ordered and confirmed that I received the correct new DVD (231).
The dealer installed in in conformance with the DTB. He actually gave me a copy of the DTB. I put the DVD into slot 1 and the car confirmed that the data on the the DVD is already loaded in the car.
But I am not getting any of the new features.. no traffic, no 3D view. Haven't checked the DVD video yet.
Anyone have any ideas? Is there another system upgrade they missed?
Thanks.
Old Nov 15, 2007 | 07:41 PM
  #70
Thanks.
Wouldn't you need a Navigation map update in addition to the update related to the DTB? Or do you already have the latest map DVD?
Old Nov 15, 2007 | 07:48 PM
  #71
trumpet1's Avatar
2007 S600
Thanks.
On 2007 models and early 2008 models, the latest Nav DVD (v.5) will not upload without first having the flash update performed on your telematics/command system. The flash update must be performed by the technician at the dealership.
Up to this point, everything you are experiencing is normal.
Old Nov 15, 2007 | 07:54 PM
  #72
trumpet1's Avatar
2007 S600
As of 10/4/07 the current navigation update is MBUSA part # BQ 646 0231. For most if not all MY07 vehicles, you will need to update the Telematics system software for the navigation update to work properly. Here is the thing if you mention MBUSA DTB P-B-82.85/512d the Telematics update is free because the navigation DVD cannot properly load.
Purchase the navigation DVD then bring the vehicle in to service with the complaint that your navigation DVD will not load, mention the DTB, and the Telematics will be updated free. In addition, check with several dealerships to receive the lowest price on the navigation DVD.
I thought I would bump the above post to allow folks to quickly review the instructions. Read the above. It should help your technician understand what's going on.
Old Nov 17, 2007 | 10:28 AM
  #73
jjkn's Avatar
Street Names at Lower Zoom Levels
Does anyone know if major street names appear on maps at lower zoom level?
Or are street names visible only at the highest zoom level as previous?
Old Nov 17, 2007 | 09:25 PM
  #74
imaohw's Avatar
s550
Street names appear only at the most zoomed in level.
Old Nov 19, 2007 | 06:46 PM
  #75
valiumvilla's Avatar
'07 S550w/AMG AndGryw/prem.grey leath4matic Night Vision Distronic ,08 ML 350, YUKON XL,'71 ChevPU
Ordering Update DVD through MBUSA
When ordering the new upgrade navigation DVD for your '07 model from the MBUSA web site be sure and NOT order it without talking to a live person. If you just click and order you will recieve the v.4 not the v.5. Why, I don't know but they do not sell v.5 unless you talk to a rep. on line.
