Can Blind Spot Assist be retrofitted?
W140 Mercedes S350, W221 S550 sport
The leds on the mirrors need power, they need wires and a control unit and the old door control unit does not seem to be capable of driving those leds. There is a 234 specific door control unit: A221 870 99 92.
The outside rear view mirror frame is different for 234: A221 810 07 76. I'm not sure if this is because of the mirror wiring harness being part of it.
Not impossible at all to change these parts but the cost from the control unit, frame and mirror glass would be a bit high relative to the gain from the leds. I would consider the feature useful without the leds but if it would only work with a new door control unit, I could consider changing that and perhaps even the other parts.
I wanted to add blind spot assist to my 500 series, because I saw it on my friends car which is the newer model of my car.I called the dealer and they said it cant be done.No one could add this feature to my model year but I was convinced someone knew how to to do it. I went to George and G&n motors and he called the dealer and ordered the part. He then retrofitted the blind spot assist on my 500 series and can do so for the 2009 and newer. So he not only can he fix them, he also can add the part from the manufacturer in some cases.
Can Blind Spot Assist be retrofitted yes G&N Motors MBZ Certified Mercedes Benz Service and Repair Center does blind spot assist installation from 2009 to latest Mercedes Benz Model Original Equipment 310-441-1956
Right and left rear view mirror housing and mirror needs to be replace , right and left front door control module needs to be replace, right and left rear bumper monitors needs to be install and needs retrofitt wiring harness for the rear monitor and finally needs to be activated with a SCN coding.
Hi
I just spoke to a guy here in Toronto, who says that he could install the blind spot assist for about $800 Canadian in my S350. However, he does not install the warning light in the side mirrors. He either installs the warning light in the Rear View mirror, sets a light up somewhere in your dash. There is also an auditable sound that you can turn on or off...
Jeff
Jeff
