funky 600 shift when driving off
Old Mar 24, 2008 | 07:01 PM
carsnob's Avatar
2007 S 600 / '06 911 Porsche C4S cab
Has anyone experience a bit of a jolt or rough shift when starting out from a cold start? It has been happening frequently and seems to be from 1st to 2nd gear. When I asked the service guy about this he said the 600 starts in 2nd gear and shifts into 3rd and that this is "normal".
Old Mar 24, 2008 | 07:14 PM
trumpet1's Avatar
2007 S600
Just to let you know, this is not normal. Their is a service bulletin about this problem and my service tech fixed this with a software flash.
Just after purchasing my car, my car did exactly as you described. I noticed a jolt just after startup and leaving the house or leaving my office. I took it to my MB dealer and they flashed the tranny module software and it completely eliminated the problem.
Then a few weeks later, I had Renntech upgrade my engine and tranny modules and the problem reappeared. I tried to live with it but I finally called Renntech and they told me to switch from the "C" mode to the "S" mode. After doing this, the problem completely went away. It's been months since then and the problem seems to be quarantined by switching transmission shifting modes.
If I were you, I would either take the car to the dealer and insist on getting this software flash done, OR try this home remedy and switch modes (S to C, or C to S) and see if the problem goes away.
I love leaving mine in the S mode.
Old Mar 25, 2008 | 12:11 AM
vonbeeler's Avatar
2005 Range Rover HSE, 2008 BMW M3 Cab d/c, 2010 GL550 (wifes), 1993 Porsche 928GTS 32kmi garage quee
starting in 1st
Not sure what the jolt is. I havn't experienced. I do know that if set in C mode it will automatically start off in 2nd gear. I always use S mode. Starts in 1st. All that torque in first gear can be quite exciting. As in any gear really.
Old Mar 25, 2008 | 09:56 AM
kenstudios's Avatar
Before you go to the dealer try this reset. Turn ignition on but don't start the engine, depress the gas pedal for about 10-12 seconds, turn ignition off and wait a few minutes before driving. This will resets it. I had a similar problem only mine was when braking and down shifting from 2 to 1. After this the tranny seemed to work well again. Your tranny will start adapting to your driving style again.
Old Mar 30, 2008 | 11:30 AM
carsnob's Avatar
Thanks, I'll check it out. Otherwise, the tranny on these cars is fantastic...
Old Apr 1, 2008 | 07:07 PM
carsnob's Avatar
thanks Kenstudios, it worked! How did that actually work????
Saved me a trip to the dealer/appt./diagnostics/loaner car etc.
Much appreciated!
Old Apr 1, 2008 | 07:20 PM
AsianML's Avatar
2007 E63
Much appreciated!
It's supposed to reset the learned shift patterns for the adaptive transmission. I just know it works since I do it often because I have a puny V6.
Old Apr 1, 2008 | 08:10 PM
JRAMGV8's Avatar
1999 C280 Previous / 2008 E350
Huge + 1.
Old Apr 1, 2008 | 10:07 PM
trumpet1's Avatar
2007 S600
Another reason I love this forum. +1
