Question About Bi-Xenon Lights
http://img525.imageshack.us/img525/9422/84927519zy5.jpg
http://www.nevadajack.us/albums/user..._1024_crop.jpg
http://upload.wikimedia.org/wikipedi...-Benz_S550.jpg
http://www.happylimo.com/S550WEB2.jpg
http://i226.photobucket.com/albums/dd155/lpm505/870.jpg
http://i226.photobucket.com/albums/dd155/lpm505/580.jpg
For example: the third picture shows on dark lens and one light lens on the right side of the car and both lenses on the left side seem light.
Picture 4 looks like the far right lens of the car is actually on whereas the 3 other lens look dark.
All in all it looks to be an angle issue at which one is standing.
If you guys could check out my other Post about the S i picked up today, id really appreciate it, thanks.
Diesel Benz, thanks again...i did look in the manual and i saw that listed there about the night assist, but i didn't think it would require a lens...but that must be it.
...Diesel Benz...you're totally right about what you said...i just checked a bunch of S550's online with and without that lens and all the ones with the lens have the P3 package...and all without the lens have the P2 or less...thanks for clearing that up...
Since I don't have these inner halogens, I cannot test on my car. But this was interesting anyway, once I did test the lamps at my garage and was surprised not seeing the centre bulbs go on at high beam or flasher mode. I should check a later copy of the car manual, perhaps it would be different.
The current Euro manual does not talk about flashers but just main beam spot lamps. Seems like the manual has now been fixed.
Overview
Front bulbs
Bulb
Type
Dipped-beam headlamps
H7 55 W
or
D1S 35 W*
(Vehicles with bi-xenon headlamps* are fitted with D1S 35 W bulbs. These bulbs must be replaced at a qualified specialist workshop, e.g. a Mercedes-Benz Service Centre.)
Additional turn signal
LED
Side lamp/parking lamp
W 5 W
Main beam headlamps
(Vehicles with halogen headlamps)
or
H9 65 W
IR projector* (for Night View Assist*)
or
H11 55 W
Main beam spot headlamp*
(Vehicles with Bi-xenon headlamps*)
H7 55 W
Cornering light function*
H7 55 W
Front foglamps
H11 55 W
Turn signal
PY 24 W
Rear bulbs
Bulb
Type
Third brake lamp
LED
Rear foglamp
(The rear foglamp only lights up on the driver's side.)
HiP 19 W
Brake lamp/tail lamp
LED
Licence plate lighting
W 5 W
Reversing lamp
HiP 16 W
Turn signal
HiP 16 W
Main beam headlamps
or
H9 65 W
or
H11 55 W
H7 55 W
What exactly does this mean...so they should be H7-55w bulbs...i don't understand what the three choices are infering...so basically the larger headlight with the lens for everyone is a Bi-Xenon high and low beam light...the second headlight (working from the out in) is the H7-55w halogen bulb for everyone except if you have the Night vision option which then would be the H11-55w halogen bulb and the third headlight is again the H7-55w halogen cornering bulb which everyone has.
Is this right? I don't know why this stuff has to be so confusing. Should my second bulb come on when i put high beam on?...ill check again, but im pretty sure it came on...according to you guys, the second bulb should not come on unless im flashing to pass someone...otherwise the Xenon should just get brighter and nothing else should happen...i feel that the xenon does get brighter when i switch high beam on, but the second bulb comes on as well...can anyone verify this...thanks
Main beam headlamps
or
H9 65 W
or
H11 55 W
H7 55 W
This is the way the equivalent halogens work on my W211 (with bi-xenons). The early user manual was written as if the inner halogens were only for flashing, the later manual explains as if the inner halogens came on as normal high beams (in addition to bi-xenons high beam mode). In addition to normal high beam, these would work as flash lights.
I believe what you said was right, for the US market. I would be interested getting the halogen high beam mode confirmed (as I cannot test myself).
To bring a bit more confusion, the cornering lights are not standard on all cars, the point is that you can get the non-xenon or all-halogen option in Europe and cornering lights do not come with those. The three options for the inner beams is explained by this too, one is the IR option, one is the bi-xenon option as in your car but then the inner lights can have a diffrent H9 halogen and that comes with the "all-halogen" Euro option (probably higher power high beams because of no bi-xenon high beam power).
Main beam headlamps
or
H9 65 W
or
H11 55 W
H7 55 W
AsianML...i had put the headlights on and then initiated the high beams...i was expecting that the xenons would get brighter and no other lights would switch on, but it appeared to me that the xenon got brighter and the halogen next to it went on as well...like Diesel Benz said, in the w211 this would happen in the US version as well...both lights would come on...my 2004 s500 had the bixenon and the halogens would initiate as well on high beam, i thought it was different for this model, but i guess not...
I haven't yet seen the inside bulb turn on yet when I flip the Hi-Beam on (but thats because our S550 has Night View Assist).
