Eeking out that very last MPG on a S600...
2013 SL 550 (Previously 2012 Porsche Panamera Turbo-S, 2015 Tesla P85D, 2007 S600, 2005 E55 AMG)
No I am not about to bail out and buy a Prius... I am though casually curious about how "efficient" or economical it is possible to run the TT V12 engine... (On standard premium gas)
On a long freeway journey (HW 101) from the Bay Area to downtown LA last week I managed to get the number up to 21.3 mpg... but I just could not budge it upwards any further... same journey and route heading back was a little less efficient at 20.0 mpg... though it was mostly 100+ outside and the A/C was working harder... interesting in itself that the A/C seems to consume around 1.3 mpg more for a 20 F external temperature difference..
The only passenger was my teenage son together with some medium weight luggage in the trunk. Speeds were all in the 75 - 80 mph range and for half of the journey I had the car under the control of distronics, (which I love) but I could eek out a bit more efficiency under manual control - just an inconsequential 0.1 or 0.2 mpg though.
Anyone with a S600 (or even a S65) achieved any higher/better numbers than 21.3 mpg? I suspect that this number must be approaching the limit. (In normal driving - not resorting to hypermiling tricks)
Chris
Chris
Would guess that 65MPH cruise on a flat stretch of fwy (like 5 through Central Valley btwn the mtns outside SF and LA regions; or NJ Tpke from NYC-Phila; or the fwys around Chic) at 65-70F outside temp would yield several more MPG....![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Also, IIRC, CA fuel mix entails some 1-2MPG less (in otherwise equivalent cars/driving) than cars w/NYC region fuel mix....
Esp in Eastern US where police hide in bushes to strictly enforce 65MPH, I suspect one's MPG is "forced" upwards....
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
What type of tires are you running? Real summer tires will give better fuel economy than all seasons or winters (usually).
It is interesting to note that the S550 can achieve much better fuel economy even though it has the same displacement, this is due perhaps to the extra 2 transmission gears and newer engine design?
What type of tires are you running? Real summer tires will give better fuel economy than all seasons or winters (usually). It is interesting to note that the S550 can achieve much better fuel economy even though it has the same displacement, this is due perhaps to the extra 2 transmission gears and newer engine design?
Though the 550 and 600 are essentially the same displacement, it seems additional factors must include the two turbo-chargers and I suspect the additional parasitic loss/friction of any V12 compared to a V8.
Chris
Good question. My wheels are 19" with the original Dunlop 255/40 R19 Y rated tires that came with the car. I have them pressurized more firmly at around 34-35 psi. (cold)
Chris
Chris
I would guess that you have nearly reached the limit on fuel economy, the S600 has a rating of 23.5 for the German market, and I believe the car requires "Super Plus" gasoline, which translates to minimum 93 US. Since california is running 91 premium, and E10 instead of real gasoline, I would not bet on getting much better, if at all.
Chris
Chris
I would guess that you have nearly reached the limit on fuel economy, the S600 has a rating of 23.5mpg for the German market, and I believe the car requires "Super Plus" gasoline, which translates to minimum 93 US. Since california is running 91 premium, and E10 instead of real gasoline, I would not bet on getting much better, if at all.
Chris
Chris
W220 S65 AMG
I did the test on a flat highway, Cruise Control @ 72MPH, no passengers. 21.3MPG.
