Newbie Owner (W221) Questions
I took delivery of a new S550 with Sport Package last month. I have only driven it 200 miles since I took delivery on Sept 1. It sits in my garage most of the time. [ Still driving the old S500 for most trips :-) ] It has been parked now for two weeks straight.
I recently noticed some water that appears to originate from the right front of the car. I am trying to figure out what this might be. As the car has not been driven for two weeks, I am thinking it can't be the air conditioner ... The windshield washer fluid is also full so no leak from there ( also no smell ... appears to be pure water ). This is the second occasion where this has occured, after another idle period.
Any thoughts on what this might be ? or some normal explanation? I am sitting on a JD Power Survey and want to turn it in clean ... I love the brand and have had a Mercedes in the family since age 16 ... so just trying to get your feedback on the periodic water drain despite the vehicle sitting in the garage ...
Thanks!
You beat me to it. I was going to say the same thing. I suspect that some reservoir may be overfilled and if you drive it , it'll correct itself and be over with. Washer fluid reservoir maybe? I remember my car had some kind of oily drip come out from under it once or twice just after buying it and then it never happened again.
How do I know this? I have 3 cars parked side by side in my garage and this summer I noticed puddles of clear liquid (like water) mysteriously appear on my garage floor. No stream of water that lead to the puddle - just random spots. Then one day after I drove one of the cars I made it a point to look under the car and could see the condensation trickling down and flowing wherever the slope was
Thanks!
If it is truly water then I'd have to ask what is the problem? Clearly just plain water isn't going to be a problem. Could be any number of things and things beside your car also. I'd say drive the car and see if it anything lights up or act funny if not forget about it.
M
I will take your advice and take it for a spin more often :-)
I appreciate the range of feedback and time spent on the replies. While the cars nearby thought is reasonable generally speaking, in my case I only have the single S550 in the garage with no other cars nearby. The reservoir overflow explantion makes sense. I will let you know if it turned out to be anything else.
