Dynamic seats
Old Jul 22, 2009 | 08:20 AM
trumpet1's Avatar
2007 S600
Dynamic seats
Has anyone noticed the dynamic seat feature turning itself off? I've been noticing from time to time that my dynamic seat feature is not working. I turn it back on by going through the comand menu, but several days later will randomly notice it's back off again. The passenger side seems to be staying on. Is there anything that I might be doing that causes this? Maybe one of the seat preset buttons shuts it off or some start cycle default overrides it . I don't know. All I know is, I am not turning it off myself via comand
Old Jul 22, 2009 | 09:56 AM
Jan AMG's Avatar
The best or nothing
It can be leak in the air bladders or defective air pump. Have your service check it.
Old Jul 22, 2009 | 12:49 PM
s600ed's Avatar
2007 s600 2007 cls63
same problem here...been to the dealer many times over this issue along with the pulse function, its something with the bladders (or not since its an ongoing issue)
Old Jul 22, 2009 | 12:50 PM
trumpet1's Avatar
2007 S600
No. It's not that they don't work, it's as if they've been switched off b/c when I go through the menu, it is turned off and I have to turn it back on.
Old Jul 22, 2009 | 03:15 PM
s600ed's Avatar
might be a problem with your seat memory...check for the entry/exit function to see if it works, it happened to me once when my seat memory malfunctioned and basically the dynamic setting goes with the seat memory..if that part's not working then it resets itself to 0
Old Jul 22, 2009 | 03:44 PM
RHBENZ's Avatar
08 S550, 08 E63, other non-Green cars
I'm so used to it, sometimes I don't even realize they are there
Old Jul 22, 2009 | 03:51 PM
konigstiger's Avatar
'71 Pinto
Service campaigns 2007080001 and/or 2007080004 may apply:
https://mbworld.org/forums/2401670-post48.html
https://mbworld.org/forums/2447542-post49.html
Old Jul 30, 2009 | 07:47 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Mine does the same thing. It'll stay on for long periods of time, and sometimes it will randomly shut itself off, or I'll start the car and it's off all of a sudden. I've just credited it to an electronic glitch which I'd assume is basically inevitable.
However recently, during a 4 hour drive, it just shut itself off (after about 3 hours), and wouldn't turn back on, neither would the passenger side. I though it was a short or something, but when I turned the car off and back on, it was able to engage again.
Old Jul 30, 2009 | 08:48 AM
Jan AMG's Avatar
The best or nothing
Mine did the same after we had fixed the leaking. It was a failure of the air pump (it was reheating).
Old Jul 30, 2009 | 09:38 AM
K-A's Avatar
K-A
Hmm, thanks for the info. Now I guess I'll put it on my checklist for the next time I go to the Dealer.
Old Jul 30, 2009 | 09:47 AM
Jan AMG's Avatar
The best or nothing
The trouble is they won't replace it unless the diagnostics shows the problem. You have to insist on replacing it just to make sure. It's this part:
Attached Thumbnails Dynamic seats-p1000515.jpg   Dynamic seats-p1000516.jpg   Dynamic seats-p1000517.jpg
Old Jul 30, 2009 | 12:16 PM
RajwanyS550's Avatar
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
mine shuts off after about 5 or 10 mts. U have to turn it back on, is there a timer or something.
Old Jul 30, 2009 | 12:19 PM
trumpet1's Avatar
2007 S600
Just to make sure everyone is clear on what I'm talking about. I'm not talking about the massage feature. I'm referring to the lateral support feature that inflates the bolsters and lateral support while making turns. My massage feature is working fine.
I just went out to my car and sure enough, it has turned itself off again after staying on for a week. Last Wednesday was the last time I turned it on.
Also, the passenger seat remains to be on, so that should indicate that the problem is not a time-dependent thing but a malfunction of some sort on the driver's side.
Old Jul 30, 2009 | 01:16 PM
Jan AMG's Avatar
The best or nothing
What is interesting that in the pre-facelift version you are not able to use the Favourite button for programming the massage function. They told me it's because you should be only using it for not more than 10 minutes because the air pump gets very hot. But in the facelift, it is possible. Makes no sense. This is a design flaw of W221, at least 2006-2009.
