07 s550/SAT antenna build date that moved it to the roof AND how do you change radio
Anyone have an idea of what date of production I should look for ???
I found a early model build and the car DID NOT have SAT radio. And it could not be added to the OEM stereo. I can not believe that a $100k car did not come standard with a SAT radio.
My 08 E has it and I can not live without it.
ALSO how do you change the radio stations ???
thanks again
1. Select the radio on the main display, then spin the command knob.
2. Select the radio on the gauge section display, then use the buttons on the steering wheel. This will seek stations.
3. To change via presets again bring up the radio on the main display, then select Presets with the command knob, scroll down to the one you want, and press the command knob.
4. To change presets using the gauge section display and the steering wheel buttons you need to have the update loaded in the system.
People should write everything twice, I might spot most of it then.
Anyway, a pity they did not implement the same as on later models where one can do both, scan presets or scan frequencies from the steering wheel.
thanks again
