Remove light scratches from wood grain???
Old Mar 18, 2010 | 07:20 PM
BGTHEMOGUL's Avatar
S550 Coupe
Has anyone had any experience trying to remove fine scratches in the woodgrain? I'm curious if this is something that can be done. I don't know what you would use that doesn't have any abrasives which can scratch or damage the wood grain finish.
I know the wood grain pieces, especially the main dash piece, are pricey to replace. So I guess the options are living with light fine scratches or try to polish them out somehow.
Old Mar 19, 2010 | 02:45 PM
jagata's Avatar
S6 LP640 E500
I would imagine the process would be like scratch removal on paint, since the wood has clear coat as well.
Old Mar 19, 2010 | 06:21 PM
RajwanyS550's Avatar
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
maybe some fine furniture polish. try on small area first.
Old Mar 20, 2010 | 10:12 AM
BGTHEMOGUL's Avatar
S550 Coupe
Any interior guys on the boards or anyone with first hand experience?
Old Mar 21, 2010 | 01:38 AM
usctrojans1's Avatar
2010 S600 sold
Lightbulb
You should check the detailing and auto finishing section of the website.
Old Mar 22, 2010 | 09:57 AM
BGTHEMOGUL's Avatar
S550 Coupe
Thanks didn't think about that.
Old Mar 22, 2010 | 06:33 PM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
The finish on the wood is a polyester clear coating that is very soft and has almost the same chacteristics as plastic. I have used Plexus plasitic polish on several of my cars. I have used microfiber cloths to apply it and buff off the residual but seem to end up with some scratches. I have been more sucessful in applying it with a sponge applicator, the same type used to apply waxes and sealants, cut into small pieces to get into the areas needing polishing and then buff out with a good micro fiber cloth. I cannot stress enough use a good cloth since a cheap micro fiber will induce more scratching than you removed.
Old Mar 22, 2010 | 06:36 PM
BGTHEMOGUL's Avatar
S550 Coupe
Sounds risky and potentially could cause more damage than help.
Old Mar 23, 2010 | 12:48 PM
lkirchner's Avatar
The wood trim in my wife's car is piano black that scratches if you look at it wrong. If you take your time and have patience the wood trim scratches will come out nicely. I detail my cars and have quite an arsenal of polishes at my disposal and have found that the Menzerna polishes work well but the Plexus does a nice job on the wood trim as well. If done properly it will cure your problem and not create damage.
