One touch sunroof closure
2007 S 600 / '06 911 Porsche C4S cab
Has anyone changed the switch or mechanism so that you can close the sunroof with one touch rather than having to hold it to close?
Cheaper cars of all makes have this so why can't an S 600?
I still agree it is strange they dropped this, probably because of some safety concerns. I cannot help with your actual question but I would check the control unit part numbers, if the later ones have the same part, then a switch and control unit version coding (possibly SW update) would hopefully fix it.
An S600 also does it if it has the standard sunroof or if it is not one of the early MY cars. Cheap cars probably don't have the pano-roof like your S600.
The Pano roof (all models) in the first year or two did not have one touch-closing. The shade for the rear roof section of the glass was the same. This was changed in wither MY08 or MY09 so that the pano would be one-touch closing and the shade for the rear roof section of the glass was also one-touch. Perhaps a software update or a new switch or both.
Check out the online 2008 manual here,p489-491. The standard Tilt/sliding roof does have Express opening and Express closing. P487.
The 2009 manual here shows both opening and closing for the panorama sunroof and the sunshade.
P410 "Express operation: To close the tilt/
sliding sunroof completely, pull the sunroof
switch past the resistance point in
direction of arrow 3 and release."
Any info on programming upgrade welcome.
My (MY08) has one-touch opening/closing of the rear share and one-touch opening of pano panel, closing is manual .. I believe it is more a feature than a bug? But would like to get it hacked for sure.
It certainly is a feature but one-touch closing was added at some point for the pano-roof too, I thought MY2008 (European MY naming) already had it. Is your car build date from early 2008 (I don't know when exactly this was changed but it was well before the facelift)?
2020 S63+2014 E550 Cab+2019 E450
You can hold down the Recirc button on the climate control and the windows and roof will close. Not exactly one touch, but it's better than reaching up and holding the button on the roof.
I thought this would not work on early W221 cars with a pano-roof, can you confirm it actually does work on a car that lacks the one-touch closing feature for the pano-roof?
One more thing, after you've closed everything using the recirc button, if you hold it down again, everything will open up. This also works on my ML. It's handy when I'm driving thru the countless Chicago constructIon zones.
The recirculation button feature has been there forever, I'm not asking if this feature works but I'm asking if this feature closes the pano-roof on a car that does not have one-touch closing from the sunroof button.
