Audio playback with SDHC card
I have tried copying them to the hard drive [music register?] and have the same problem [as may be expected]. Also, original [bought] CD's will not copy from the cars player onto the music registers hard drive [as I would expect!]
Help! anyone got detailed info about how I get my music in itunes or Windows onto an SD card and to play in my car?
The iPod handles the "difficult" parts of digital audio playback which COMAND seems very slow at. Apple has really perfected that part.
Also, it's more elegant to sync. And even an old used iPod works really well.
Ian P, are you sure your songs are correctly coded? iTunes default does not work, on older W221 cars neither Windows Media formats, I'm not sure if the 2010 should do that as some later Comand units do.
I guess the 2010 Comand has a memory card slot instead of a PCMCIA adapter? Have you checked it supports SD HC cards? I think the new NTG2.5 does not (thanks to all who have complained about the PCMCIA interface that supports all formats through an adapter, now MB shows they listen to their customers, unfortunately).
I would try with an SD card and put a few MP3 titles there first. Another option would be to read carefully the car manual, the solution is there, no doubt about that.
I'm using the SD card exclusively, and haven't noticed any latency issues. The music starts right away and I can switch between the tracks with no delay either.
I use a PCMCIA Compact Flash reader with 16 GB CF cards with no issues.
http://dougscripts.com/itunes/script...nvertandexport
Did you solve the problem?
I have PCMCIA + Transcend 32GB 400x CF card, but I can only get about 2700 songs (12GB) recognized, not the 4000 specified in the manual.
As Diesel Benz says, the slowness accessing the CF card is more noticeable the first time or so the card is inserted. It seems as though it caches the folders and or files on the card first.
